92 Civic LX won't start...
Old Jan 9, 2005 | 03:29 PM
diewX3's Avatar
Default 92 Civic LX won't start...
Car: 1992 Civic LX
Miles: 180k miles
Engine: Stock D15??? not sure on the engine code..
Problem: - Turns over but won't start. Ever since it's been snowing since Friday I haven't been able to start the car. I've already checked the distributor cap and no moisture in there. Already removed the spark plug and inserted it into the coil to check for spark, it's good. So far ignition seems to be ok, now how would I check if fuel is getting into the cylinders? Thanks in advance if you can help me please
EDIT: forgot to add there is 3/4 gas in there in case someone wanted to ask
Old Jan 9, 2005 | 07:17 PM
diewX3's Avatar
bump anyone
Old Jan 9, 2005 | 07:30 PM
PrettyLude's Avatar
when u took the plugs out, were they wet?
Old Jan 9, 2005 | 09:01 PM
diewX3's Avatar
Default Re: (PrettyLude)
yeah they looked normal to me slight brown almost black i can hear the fuel pump when I turn the key to on. Anyone else have any suggestions on what to check?
HondaNoob92
May 17, 2018 04:50 PM
mete4d
Jan 19, 2018 12:23 PM
mxer201
Aug 13, 2011 08:45 AM
Patman
Feb 6, 2007 11:28 AM
