Water Temp Gauge
Old Jan 9, 2005 | 03:23 PM
ferio 95's Avatar
Default Water Temp Gauge
Ok ive had this water temp gauge forever but never installed it because i couldnt find anywhere the sensor would fit. Anyone have a clue on where i could tap for it, or is it useless? Also whats normal operating temp for a gsr?
Modified by ferio 95 at 6:46 PM 1/9/2005
Old Jan 9, 2005 | 03:33 PM
havok hybrid's Avatar
Default Re: Water Temp Gauge (ferio 95)
Take out the Stock sensor *its in the head under the distrubotor*... and replace it with the new sensor .... then you new guage will work and the stock honda one will not ....
Old Jan 9, 2005 | 03:46 PM
ferio 95's Avatar
Default Re: Water Temp Gauge (havok hybrid)
wont fit tried it already
Old Jan 9, 2005 | 05:42 PM
vtekstorm's Avatar
what about the coolant drain bolt in the back of the block? does it fit there?
just a thought
Old Jan 9, 2005 | 11:02 PM
ferio 95's Avatar
Default Re: Water Temp Gauge (vtekstorm)
you mean the huge *** bolt????
Old Jan 10, 2005 | 09:58 PM
ferio 95's Avatar
Old Jan 12, 2005 | 01:43 PM
vtekstorm's Avatar
yea that bolt on the back of the block maybe it might fit there
Old Jan 12, 2005 | 02:27 PM
msmotorsports's Avatar
Using the upper radiator hose, you can fab up a small pipe and weld in a bung that will accept the fitting you have.
Old Jan 12, 2005 | 04:41 PM
BIG RICH's Avatar
Default Re: Water Temp Gauge (msmotorsports)
heres what I did. I ordered the hasport K-series coolant sensor adapter and used a couple brass fittings( found at a local hardware store) and made the autometer sensor fit inside that hole.
Old Jan 12, 2005 | 04:47 PM
floridaCharlie's Avatar
Default Re: Water Temp Gauge (BIG RICH)
do you have any pics, Big Rich????
Old Jan 12, 2005 | 07:47 PM
Dan GSR's Avatar
Old Jan 13, 2005 | 05:15 AM
Default Re: Water Temp Gauge (Dan GSR)
thanks a lot that makes it seem easierthen what i was thinking of
steveharrmr23
Nov 11, 2008 07:31 AM
TypeR15
Feb 24, 2004 12:29 PM
ten_30
Oct 2, 2002 11:08 AM
