Help: Head Flanges warping after tig welding...
Old Jan 9, 2005 | 02:45 PM
wade's Avatar
Default Help: Head Flanges warping after tig welding...
We have been Tig welding manifolds for years now and it seems we are on a trend of our head flanges warping out, can anyone add some insight?
Old Jan 9, 2005 | 02:54 PM
Engloid's Avatar
OG Fabricator
Default Re: Help: Head Flanges warping after tig welding... (wade)
Too much heat input can do that. It can also be caused by too large of gaps between the flange and tube...causing more shrinkage than before.
Old Jan 9, 2005 | 03:03 PM
david@didrace.com's Avatar
Like Engloid said, too much heat. Here's one of the jigs I made, it is made out of 3/8" aluminum. I tapped it to the bolt pattern of the stock manfolds and put in studs. I had stainless flanges and copper gaskets custom made for the exhaust. I just weld the flanges while they're bolted down to the plate and I don't have any problems with warping because the copper gaskets and aluminum plate transfer the heat away from the flanges.
Old Jan 9, 2005 | 03:24 PM
Engloid's Avatar
OG Fabricator
Default Re: Help: Head Flanges warping after tig welding... (backpurge)
You can also play with a slight amount of "pre-bow" in the opposite direction. If you prebow too far, it's really easy to just go over a couple welds and draw it back.
Old Jan 9, 2005 | 05:08 PM
evilone's Avatar
Default Re: Help: Head Flanges warping after tig welding... (Engloid)
why not just machine the surface, kinda like decking a head??I've done a ton of j pipes for dsms and would get boost leaks,now i just use a belt sander and a steady hand, never had and issues after i started doing this.
Old Jan 9, 2005 | 05:11 PM
wade's Avatar
we do get them resurfaced, but that isnt what we want to do each time, too much down time. We currently bolt the head flange to a duplicate flange to 'try' and keep it true, but after its all done and said, still warps slightly once its off.
Ill keep you all updated.
Old Jan 9, 2005 | 05:18 PM
ExploitedRacing-HR's Avatar
Either that or use a large Belt sander which is pretty comon to just hold it down on one until its flat. I personally use the mill or a boring bar.
Old Jan 9, 2005 | 05:22 PM
Engloid's Avatar
OG Fabricator
make some kind of fixture that will help you bow them back straight. Something like what I made in the pic below to help the pipe from bowing would work fine. If necessary, you could put a few jack screws in there instead of just one.
Or maybe take that extra flange and bend it in the amount of prebow you want...then weld something on it to hold it bowed. Then all you'd have to do each time is just clamp the header flange to the one that's bowed...and weld it up.
edited to add the pic:
Modified by Engloid at 7:15 PM 1/9/2005
Old Jan 9, 2005 | 05:33 PM
wantboost's Avatar
Who is Mr Robot?
what pic below?
Old Jan 9, 2005 | 06:25 PM
Masta's Avatar
What about bolting it to an old cyl. head? It would keep it nice and flat AND the alum. would suck out a great deal of heat.
D.
Old Jan 9, 2005 | 06:29 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Masta)
^ i think that would work. sounds like a good idea. i guess that anything you can bolt the head flange down to and get it nice and tight would work to keep the flange from warping, correct?
Old Jan 9, 2005 | 07:57 PM
evilone's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">we do get them resurfaced, but that isnt what we want to do each time, too much down time. We currently bolt the head flange to a duplicate flange to 'try' and keep it true, but after its all done and said, still warps slightly once its off.
Ill keep you all updated.</TD></TR></TABLE>
honestly if it takes more than 5 min i would be shocked
Old Jan 9, 2005 | 08:15 PM
Bailhatch's Avatar
Default Re: (Masta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Masta &raquo;</TD></TR><TR><TD CLASS="quote">What about bolting it to an old cyl. head? It would keep it nice and flat AND the alum. would suck out a great deal of heat.
D.</TD></TR></TABLE>
thats how i do it. I weld 2/3 of it bolted down, then finish it off the head and they come out pretty close to perfect.
Old Jan 9, 2005 | 08:33 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Bailhatch)
mine looks perfect, adam. no warpage from what i can tell.
Old Jan 10, 2005 | 07:16 AM
Ekasey's Avatar
Try and keep the heat out of course, but we just resurface ours on a 20" face grinder couple passes and wallaH! no leaky no more
Old Jan 10, 2005 | 08:32 AM
evilone's Avatar
Default Re: (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">Try and keep the heat out of course, but we just resurface ours on a 20" face grinder couple passes and wallaH! no leaky no more</TD></TR></TABLE>
92cxturbo
Welding / Fabrication
Apr 18, 2011 07:03 AM
boostedgsr1234
19
Apr 5, 2008 09:07 AM
meanEG
Feb 2, 2006 07:15 PM
Kyssrt-4
May 5, 2005 10:11 AM
philipwight
Mar 9, 2005 10:19 PM
