Need Pinouts for OBD1 Auto TCM to ECU to Wiring Harness
Old Jan 9, 2005 | 09:45 AM
russjameson's Avatar
Default Need Pinouts for OBD1 Auto TCM to ECU to Wiring Harness
I have a 97 Civic EX and I swapped in a B16 with a 94 LS auto Tranny into the car.
I am running a JDM P30 Manual ECU with a 94 LS Automatic TCM.
I ordered a Conversion harness from Boomslang to include the OBD1 P30, the OBD1 TCM and Convert to a OBD2A Engine Wiring Harness. This was their first attempt at this conversion so it might have problems.
I recieved the Conversion harness and it looks great but I think the wiring is wrong.
I can't physically place the car in 1st gear and the shifter interlock system doesn't work. Also the car shifts very hard and does not stay in 1st or 2nd gear for long enough to actually get some power out of it. Shifts at around 2700 RPM, also it doesn't downshift when coming to a stop.
My question is does anyone know the pinouts of the TCM and the ECU so I can check to see if the harness I have has a problem or maybe if my TCM is bad.
I am trying to fix this problem so I can sell the car.
Thank you for your time.
Russell Brown
Virginia Beach, VA
Old Jan 9, 2005 | 07:51 PM
Default Re: Need Pinouts for OBD1 Auto TCM to ECU to Wiring Harness (russjameson)
Bump.........for a helping hand.....
Any one have the PDF file from a 94 integra Manual?
showing the TCM and ECU pinouts........
any one
Old Jan 9, 2005 | 09:30 PM
Turbogixxer's Avatar
Well, I cant really post clear wiring diagrams for what you need, if you PM your address. I will snail mail them to you. I have them, but I can not size them right so they are easy to read.
Or
http://www.streetlegalkhk.nl/m...nuals/
Old Jan 10, 2005 | 02:26 AM
hondaguyef's Avatar
Default Re: Need Pinouts for OBD1 Auto TCM to ECU to Wiring Harness (turbogixxer)
Sick Link TurboGixxer
Old Jan 10, 2005 | 03:54 AM
Thanks man I'll check it out when i get home.......damn military wont let you download files that big at work...
Thanks for your help
Old Jan 17, 2005 | 09:20 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russjameson &raquo;</TD></TR><TR><TD CLASS="quote">I have a 97 Civic EX and I swapped in a B16 with a 94 LS auto Tranny into the car.
I contacted you some time ago when you first found your problem with your OBD2-1 harness. I offered my services and guaranteed you would have a harness that is worry free and I would be able to answer all your tech questions. It sounds like the harness has not been properly assembled along with a manual ecu. PM me if you would like me to help you out.
Jason
http://www.JKobdconversionharness.com
codymm1014
Aug 23, 2012 10:36 PM
keung71182
May 25, 2012 12:38 PM
-Todd-
Feb 5, 2006 03:58 PM
boostedcivicsir
Oct 5, 2004 07:34 AM
apron8
Aug 14, 2003 03:21 PM
