rattlin and squeekin noise
Old Jan 9, 2005 | 07:51 AM
jayare05's Avatar
Default rattlin and squeekin noise
ok this noise has been drivin me nuts. when my car is warmed up, when it idol's normally i hear this squeekin sound comming from right underneath the floor boards infront of the passenger seat.. then.. i also hear this rattlin noise everytime i shift sounds like somethin rubbin on the exhaust, but i removed both heat shields just to see if that was it and it wasnt.. stock exhaust..
p.s. when i jack the car up, the squeekin goes away. any ideas?
Old Jan 9, 2005 | 11:13 AM
jayare05's Avatar
Default Re: rattlin and squeekin noise (jayare05)
bump
Old Jan 9, 2005 | 12:22 PM
Jimmy's Avatar
Global Moderator
I think it could be the honeycomb in your cat coming loose.
Reasons why this would happen:
1) Really old worn out catalytic converter
2) Bad a/f mixture.
I do NOT reccomend buying a high-flow cat if this turns out to be the problem.. They break easier than stock ones.
How to test your catalytic converter:
Get under your car and tap your cat easily with a rubber mallet... When you hit it if you hear some form of noise then you need to replace it.
Buy a used one off of a 99-00 civic ex or 92-95 civic.. depending on what base model civic you own.
Goodluck
Old Jan 9, 2005 | 01:09 PM
jayare05's Avatar
that would explain the rattlin noise.. wonder what thw squeekin is.. when i was underneath there, i noticed that there is 2 springs that are between the header and the cat.. im thinkin that might explain the squeekin noise.. because i see nowhere that the exhaust can be rubbing. theres enough clearance between the header and oil pan, and it cant be the heat shields because i took them down to see if that was it and obvisally it wasnt.. imma tap the cat with a rubber mallet tonight to see if thats it.. any other ideas ?
Modified by jayare05 at 2:48 PM 1/9/2005
Old Jan 9, 2005 | 05:27 PM
jayare05's Avatar
ttt
Old Jan 9, 2005 | 05:34 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayare05 &raquo;</TD></TR><TR><TD CLASS="quote">that would explain the rattlin noise.. wonder what thw squeekin is.. when i was underneath there, i noticed that there is 2 springs that are between the header and the cat.. im thinkin that might explain the squeekin noise.. because i see nowhere that the exhaust can be rubbing. theres enough clearance between the header and oil pan, and it cant be the heat shields because i took them down to see if that was it and obvisally it wasnt.. imma tap the cat with a rubber mallet tonight to see if thats it.. any other ideas ?
Modified by jayare05 at 2:48 PM 1/9/2005</TD></TR></TABLE>
I'm trying to help you and i'm almost 100% sure this is your problem.
Your bumping a thread that doesn't need to be bumped.
Old Jan 9, 2005 | 06:28 PM
jayare05's Avatar
Default Re: rattlin and squeekin noise (Jimmy)
alright.. well imma replace that cat when i get my exhuast in.. thanks for the help jimmy
97teg415
Jul 25, 2016 05:46 AM
xagix
Jan 19, 2006 02:07 PM
vietnogi
Mar 24, 2005 04:51 PM
H22A4 Prelude
Jan 22, 2005 05:16 PM
hooptie157
Feb 6, 2002 06:47 PM
