CEL 14- IACV on a 99 JDM ITR swap
Old Jan 8, 2005 | 09:58 PM
9krpm's Avatar
From: see my earring from a MILE, bling bling, Va, USA
Default CEL 14- IACV on a 99 JDM ITR swap
Ok , so I just bought a car with a 99 JDM ITR swap into a 2001 GSR chassis.
It is BONE stock. No mods. It has a Kenji chipped p28 in it.
The motor only has 40k on it, and the previous owner never had any problems before.
I get the car home, and it throws a CEL 14, but only once. The car is incredibly jerky at part throttle driving, and seems like it is stuttering some times.
I took the IACV off and cleaned it with carb cleaner. I drove it home, and it drove PERFECT. I started it back up to come to work, and the car did it again on the drive back up here. (Jerking and running rich). This JUST started happening.
Does anyone know what this could be? Is there anything else i could check? Is it possible that I'd have to replace the IACV instead of just cleaning it?
Thanks for all your help.
Old Jan 9, 2005 | 12:17 AM
1Quikgsr's Avatar
try cleaning it.. or repin it opps edit you cleaned it then you have to repin it
Old Jan 9, 2005 | 01:41 AM
9krpm's Avatar
Default Re: (1Quikgsr)
repin it? how do you do this?
Old Jan 9, 2005 | 09:22 AM
9krpm's Avatar
Default Re: CEL 14- IACV on a 99 JDM ITR swap (9krpm)
bump?
Old Jan 9, 2005 | 09:38 AM
Tweakmeister's Avatar
I think by Repin he means re-pin (out) the connection.
Old Jan 9, 2005 | 09:56 AM
9krpm's Avatar
Default Re: CEL 14- IACV on a 99 JDM ITR swap (Tweakmeister)
yeah I am still lost. I'd like to get a new IACV off of a friend and hook it up and see if it still does it.
Old Jan 9, 2005 | 03:55 PM
9krpm's Avatar
anybody have any input on this? I just have a feeling that when i replace the iacv that the problem will still exist.
Also I have a kenji chipped p28. That is the only mod performance wise to the car, and when i put a regular p28 in there thats not chipped, the CEL comes on right away, and the car wont even start.
With the Kenji ECU, it runs, BARELY, but it runs soooo rich.
Has anyone else ever had anything similar to this problem?
Old Jan 11, 2005 | 12:25 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">I think by Repin he means re-pin (out) the connection.</TD></TR></TABLE>
I'm sure some wiring was done to get whatever harness you are using to work. Check the connections. Make sure something is not grounding out.
em1_niokka
Apr 7, 2012 11:43 PM
virus.EK
Jan 12, 2007 07:38 PM
99EeeKay
Apr 9, 2006 10:27 AM
klei2fast
Dec 13, 2005 09:42 PM
lakerschamp2000
Apr 8, 2003 06:09 AM
