Suspension & Brakes Theory, alignment, spring rates....
removing top nut on tein ss
Old Jan 8, 2005 | 02:00 PM
Spn_BB2's Avatar
Default removing top nut on tein ss
ok you know on the top nut of the shock where(on the oem suspeneion) you have to use a allen wrench to hold the shock stem still while you loosen the nut? well how do you do this on tein ss because all that happens when you put the allen wrench in there is adjust the dampening.
Old Jan 9, 2005 | 02:18 PM
Spn_BB2's Avatar
anyone?
Old Jan 10, 2005 | 02:36 PM
Spn_BB2's Avatar
hundereds of people on ehre with this suspension and no one can gimme a answer?
Old Jan 10, 2005 | 10:22 PM
cxSHOE's Avatar
Default Re: removing top nut on tein ss (Spn_BB2)
visegrip the shaft and turn slowly... it should only be at 25 ftlbs so it will move without much turning..
done it several times no problems at all... i actually have two nuts at the top,, i dont need to mess with my suspension for fear of the nut coming loose.
and the same goes when you torque the nut down putting it together. some people grip that little notch at the top. if you look it will be two flat sides.. but i dont like that since it could damage the ****. i prefer to grip the shaft instead...no problems and no marks and is still smooth..
Old Jan 10, 2005 | 11:44 PM
dkdelsol83's Avatar
Default Re: removing top nut on tein ss (cxSHOE)
dont do that...if u vise grip the shaft it will leave an indension in the the shaft and when it is compressed it will rub the inside and bust the gas chamber
Old Jan 10, 2005 | 11:58 PM
cxSHOE's Avatar
Default Re: removing top nut on tein ss (dkdelsol83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkdelsol83 &raquo;</TD></TR><TR><TD CLASS="quote">dont do that...if u vise grip the shaft it will leave an indension in the the shaft and when it is compressed it will rub the inside and bust the gas chamber </TD></TR></TABLE>
how did you torque it to 25lbs then???
or call tein and ask them how to do it...
the shaft is not that weak but do what you want...i did it without any marks or any problems so i can only offer my solution.
Old Jan 11, 2005 | 12:00 AM
cxSHOE's Avatar
also if you grip it at the top of the shaft like i did there is no way it will even touch the gas chamber due to the bump stop..
Doom325
Suspension & Brakes
Jul 19, 2010 06:02 PM
4thgenx42
May 28, 2007 12:20 AM
COMplex.
Honda Civic (2006 - 2015)
20
Apr 20, 2007 02:39 PM
Civic2Integra
Suspension & Brakes
Jan 2, 2007 05:22 AM
ITR_1211
Dec 25, 2003 09:11 PM
