Those running 2.5"+ exhaust: Safe to remove gas tank heat shield?
Old Jan 8, 2005 | 09:48 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Those running 2.5"+ exhaust: Safe to remove gas tank heat shield?
I'm having a problem with my exhaust hitting my heat shield around the gas tank with my 60mm Tsudo/Thermal exhaust setup and rattling like crazy. It's driving me nuts!
I'm looking to upgrade to a 2.5" or 3" exhaust in the future and I'm wondering if you should take off the heat shield around the gas tank or bend it back or what so that it doesn't rattle.
Is that safe?
Old Jan 8, 2005 | 09:56 AM
11psiTurboSI's Avatar
Default Re: Those running 2.5"+ exhaust: Safe to remove gas tank heat shield? (boostincoupe)
If it doesn't touch, you should be fine... My Thermal 3inch was hitting my heat shield where the cat is located and I took it off with no problems.
DA_DRE
Welding / Fabrication
27
Apr 4, 2008 03:08 PM
LaOstha
14
Oct 11, 2005 07:43 PM
AnToNy
36
Sep 15, 2005 07:44 PM
wrXtian
10
Sep 14, 2005 10:26 PM
kholmes
10
Aug 30, 2004 06:47 PM
