valve spring height
Old Jan 8, 2005 | 07:49 AM
jbscivichb92's Avatar
Default valve spring height
i have been hearing some ticking noise comeing from my engine. i'm assuming valvespring height needs to be checked. can someone give me the specs for the intake and exhaust valve springs on a b16a?
Old Jan 8, 2005 | 08:12 AM
saywhat's Avatar
Default Re: valve spring height (jbscivichb92)
Honestly I went to look for my book so I could tell you, I couldn't find it, but then I started thinking to myself that you should have a book too. So the moral of the story is please don't try to adjust the valve clearances without a book or manual of some sort. I gaurantee it will make the job go 100% smoother, and you will know what you are doing. Good luck!
Old Jan 8, 2005 | 08:47 AM
jlacoy82's Avatar
71.192.16.183
Default Re: valve spring height (saywhat)
Straight from helms for a b16a engine:
Intake: 0.15 - 0.19mm (0.006 - 0.007 in)
Exhaust: 0.17 - 0.21mm (0.007 - 0.008 in)
Might want to lookup a how-to for this as well, you arent adjusting valvespring height, your adjusting valve lash, or basically the free play between the rocker arm and valve stem.
Old Jan 8, 2005 | 02:55 PM
Default Re: valve spring height (jlacoy82)
thanks. i only have a helms for the old d15. i haven't gotten one yet for the b16a. i've done it on a sohc before. it shouldn't be much different on dohc. i just wanted to double check the specs.
aaronhume
Mar 7, 2006 06:17 PM
CBURKE
Sep 17, 2005 09:05 AM
Stryker908
Aug 12, 2003 09:58 AM
GlowingRotorsXSI
May 30, 2003 02:48 PM
ysrhatch
Jan 16, 2002 02:43 PM
