leaking roof
Old Jan 8, 2005 | 07:36 AM
stevescivic's Avatar
Default leaking roof
occasionally after it rains it feels like the back carpet on my 90 crx si is slightly damp. Where would this water be coming in from? Someone was saying that it seeps in through the washer nozzle at the back of the car?
How hard is it to remove that nozzle and replace that gasket that is underneath it?
Thanks
Old Jan 8, 2005 | 08:22 AM
Shirk's Avatar
Default Re: leaking roof (stevescivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevescivic &raquo;</TD></TR><TR><TD CLASS="quote"> Someone was saying that it seeps in through the washer nozzle at the back of the car?
Thanks
Correct. I don't know how the access for it is without the sunroof, but we had a little trouble getting the washer out. Switched both washer and gasket. Still get some drops in the rear seat after real heavy rain showers, but other than that it's fixed
Old Jan 10, 2005 | 09:01 PM
Default Re: leaking roof (Shirk)
when your roof nozzle leaks can you actually see water dripping from the inside roof? My car shows no signs of actually leakage that I can see. All i can feel is a barely perceptible dampness in the rear carpet area and some condensation in the spare tire well area.
Old Jan 10, 2005 | 09:05 PM
skittyscott's Avatar
steve, thats from your taillights... try replacing your gaskets and be thankful your car doesnt leak from the roof
Old Jan 10, 2005 | 09:15 PM
doublethink's Avatar
Default Re: leaking roof (skittyscott)
mine leaks from the roof.
it sucks ***.
im going to have to silicon those two seals on the roof outside the car.
Old Jan 10, 2005 | 09:17 PM
Mr_CRX's Avatar
Default Re: leaking roof (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">mine leaks from the roof.
it sucks ***.
im going to have to silicon those two seals on the roof outside the car.</TD></TR></TABLE>
ditto
Old Jan 11, 2005 | 04:03 AM
Shirk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skittyscott &raquo;</TD></TR><TR><TD CLASS="quote">steve, thats from your taillights... try replacing your gaskets and be thankful your car doesnt leak from the roof</TD></TR></TABLE>
Water in the spare tire compartment is most likely worn out/cracked gasket for the tail lights. Just remove the plastic panel and take a look on the gasket. It will probably be wet on the inside
Old Jan 11, 2005 | 04:54 PM
i looked at my tailight seals and they don't look cracked but crushed. Perhaps I should replace them? Are they expensive?
I think I will take my car to honda to have them replace the rear washer nozzle gasket so I don't have to worry about water getting into the car.
Is it easy to change myself or is it a bitch to remove?
Thanks
user1122
Jun 11, 2015 04:44 AM
SECURITY
18
Jul 28, 2005 10:21 PM
Seedc2
Apr 1, 2005 09:51 PM
Fink2iCe
Aug 29, 2004 11:03 AM
