Chip maps
Old Jan 8, 2005 | 06:53 AM
Doug684's Avatar
Default Chip maps
Ok I have a 91 Civic SI with a D16Y8 going in it. I rebuilt it with 10.5:1 c/r JE's, eagle rods, port and polished Y8 head, DC header, ram air intake, and catback exhaust. v-tec engagement is going to be about 4500 rpm.
Well I am still running a PM6 ecu and will need a chip for it. The guy I know on here usually deals with turbo and has no idea how to burn a chip for this setup besides just a regualar Y8 base map. Does anyone have a map for this setup or can make one? Thanks a lot! Doug
Old Jan 8, 2005 | 10:37 AM
Jim Truett's Avatar
Default Re: Chip maps (Doug684)
What are you looking to use for VTEC fuel and timing maps? You might want to look at http://www.pgmfi.org for the PM6 one wire VTEC solution.
Old Jan 8, 2005 | 12:25 PM
hondaguyef's Avatar
Default Re: Chip maps (Jim Truett)
I would tell the guy you are having burn the chip for you just burn a P30 maybe even a p72 map and then you both could tune from there. I use Uberdata(OBD1) or else I would make a map for you.
Phil
Old Jan 8, 2005 | 12:36 PM
Jim Truett's Avatar
Default Re: Chip maps (hondaguyef)
How do you put an OBD-1 10x20 map on a OBD-0 15x17 map base?
toony
Engine Management and Tuning
21
Sep 12, 2015 01:52 PM
ef9_civic_hatch
May 11, 2007 11:28 PM
Civicman86
Mar 24, 2007 01:15 PM
chu77
Sep 28, 2006 07:28 AM
Doug684
Jan 8, 2005 10:31 PM
