Clutch/Tranny Fluid
Old Jan 7, 2005 | 09:33 PM
mikester_91's Avatar
Default Clutch/Tranny Fluid
Alright I gotta 92 si, so...my question is... are the clutch and tranny fluid the same things to drain and refill? Cuz i know you're supposed to change the tranny fluid through the drain bolts in the passenger side wheel well. So how would you drain and refill the clutch fluid?
Old Jan 7, 2005 | 10:33 PM
Justateg's Avatar
Default Re: Clutch/Tranny Fluid (mikester_91)
there is a bleed valve on your clutch slave cylinder. I drive and integra and my sisters prelude is an auto so im not sure where your fill is. its one of your reservoirs though just read the tops of them it takes a dot3/dot4 fluid, just like brake fluid
Old Jan 7, 2005 | 10:40 PM
bb6h22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikester_91 &raquo;</TD></TR><TR><TD CLASS="quote">Alright I gotta 92 si, so...my question is... are the clutch and tranny fluid the same things to drain and refill? Cuz i know you're supposed to change the tranny fluid through the drain bolts in the passenger side wheel well. So how would you drain and refill the clutch fluid?</TD></TR></TABLE>
Tranny fluid is not the same as clutch/hydraulic fluid.
You use brake fluid for the clutch and tranny fluid in the tranny.
Old Jan 7, 2005 | 10:47 PM
eK9aT10pSi's Avatar
Default Re: Clutch/Tranny Fluid (bb6h22a)
for the tranny, i use mobil 1 syn 10w30
for the clutch line, i use valvoline syn brake fluid
Old Jan 7, 2005 | 11:26 PM
PrettyLude's Avatar
gm synchromesh works good too
Old Jan 12, 2005 | 07:00 PM
Shehzada's Avatar
Default Re: Clutch/Tranny Fluid (eK9aT10pSi)
I have a 92 LX that is difficult to get into 1st gear and grinds when put into 3rd. All the other gears are very smooth to get into. I bought it 2 weeks ago and wanted to know if switching to Redline MTL will do me any good.
I have heard of horror stories of the synchros going bad after people put in Redline. Has anyone tried putting Lubegard Gear Fluid additive?
A new clutch kit was installed by AAMCO 3K miles ago by the previous owner where they also put in a reconditioned differential with a new spyder gear. I was expecting the tranny to be shifting flawlessly......but it is not (especially in cold weather). Any help would be appreciated.
Old Jan 27, 2005 | 08:44 AM
CurlyDE's Avatar
Default Re: Clutch/Tranny Fluid (Shehzada)
I'm using Honda's manual tranny oil in my Prelude.
I have been using Redline MT-90 in my other car for 2-3 years and have had no issues.
TEAM JDM-P
Jul 25, 2007 12:27 PM
fanta!
12
Dec 30, 2005 06:59 AM
s2kkid
Oct 17, 2005 08:09 PM
andrewasf77
Jun 19, 2003 07:32 PM
