trans fluid change
Old Jan 7, 2005 | 04:43 PM
dubbedcorde's Avatar
Default trans fluid change
im changing my half shafts tomarrow and i was woundering since i dont have ne honda trans fluid here in town and since i have a auto would the b&m trick shift stuff work i know that it is for auto trans but i know if u dont use the honda trans fluid its not good on the trans thanks a lot
Old Jan 7, 2005 | 05:47 PM
berettagtz117's Avatar
Just use some good mobil or Castrol 10w-30 for your tranny thats basicaly what honda fluid is. You can use synthetic if you would like to..
Old Jan 7, 2005 | 06:27 PM
Default Re: (berettagtz117)
i was thinking the synthetic b&m trick shift i heard it firms up shifts and other little things and since i got a auto im stuck with i figured anything might help but i cant put in a manual cuz its my girls car but oh well
Old Jan 7, 2005 | 06:51 PM
insomniac791's Avatar
You can use regular 10-30 motor oil but I heard very bad thing about synthetic motor oil in trannys. If you want to go synthetic use the trick shift because it is actually designed for trannys. I used regular motor castrol 10-30 oil in my old tranny and it held up fine. I do think honda fluid is the best though. If you can't get any where you are I work near a Honda dealership I could pick some up for you and you just pay for it and shipping.
Later
Matt
Old Jan 7, 2005 | 06:57 PM
alotawatts's Avatar
Default Re: trans fluid change (dubbedcorde)
Put the 10/30 in your engine not your auto-trans. If you cannot get Honda ATF do a forum and Google search for the best substitute ATF.
Old Jan 7, 2005 | 07:06 PM
SOHC4life 96's Avatar
Default Re: trans fluid change (alotawatts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts &raquo;</TD></TR><TR><TD CLASS="quote">Put the 10/30 in your engine not your auto-trans. If you cannot get Honda ATF do a forum and Google search for the best substitute ATF.</TD></TR></TABLE>
Yup, don't put motor oil in your AUTO tranny. There are plenty of auto transmission fluid substitues out there.
Old Jan 7, 2005 | 07:18 PM
thats why i was just thinking the b&m trick shift auto trans fluid it said great for all auto trans i checked 4 parts stores wal mart even auto zone and no one has honda atf and the closest honda dealer is 75 or 85 miles away and i dont have time to get there and back cuz i have to do the swap tomarrow its the only time i got it sux but o well i think i will just top it off after i do the swap with some normal atf and get some honda stuff from the dealership next weekend when i got time only thing i know to do
Old Jan 8, 2005 | 09:46 PM
oh Sorry I missed the part about it being an AUTO. Sorry about that
Matt
hawks85
20
Jul 19, 2017 03:33 PM
NorCal_ej1
21
Jan 5, 2014 03:19 PM
deegaw1126
Honda CR-V & Element
Aug 2, 2012 04:43 AM
audiphile
Jul 8, 2004 08:16 PM
Rah Rah
Dec 25, 2001 03:18 PM
