balljoints
Old Jan 7, 2005 | 03:30 PM
MPALUGHI's Avatar
Default balljoints
my ball joint is in bad shape would it be a difficult fix for a novice wrencher or should i just bring it to a shop
Old Jan 7, 2005 | 04:45 PM
eda6's Avatar
Default Re: balljoints (NYCHUSLA)
If you have a vise, snap ring pliers, 4 lb hammer, ball joint press and tools to remove knuckles you can do it yourself. It's pretty simple. Takes me about 1 hour.
I suggest you try it first. If it has to go to the shop remove the knuckle yourself to save some $.
if you have problems post them here
Old Jan 7, 2005 | 08:05 PM
mamaboy's Avatar
getting the ball joints off of the suspension components is going to be fun the a arm, tie rod, and lca.
Old Jan 7, 2005 | 09:23 PM
riceisnicenv's Avatar
Default Re: balljoints (mamaboy)
i couldn't get the ball press to work. i used PB blaster to lube it up then beat the crap out of it with a hammer for about 30 minutes until it came out.
Old Jan 7, 2005 | 09:36 PM
eda6's Avatar
Default Re: balljoints (riceisnicenv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceisnicenv &raquo;</TD></TR><TR><TD CLASS="quote">i couldn't get the ball press to work. i used PB blaster to lube it up then beat the crap out of it with a hammer for about 30 minutes until it came out. </TD></TR></TABLE>
The ball joint press is used to install.
Remove the ball joint w/o pulling the knuckle. Known as the "craftsman trick"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude &raquo;</TD></TR><TR><TD CLASS="quote">
1.) make sure the lower control arm is still attatched to everything.
2.) jack up the suspension assembly by the rotor.
3.) insert a 1/2" socket wrench in between the knuckle and the lower control arm.
4.) lower the jack.</TD></TR></TABLE>
Old Jan 8, 2005 | 09:19 PM
Default Re: balljoints (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah it wouldn't install either... so i banged the joint in also.
Old Jan 9, 2005 | 05:19 PM
Brick Top's Avatar
do it yourself, its easy. find some instructions.
Modified by efhatch at 11:57 PM 1/9/2005
Old Aug 28, 2005 | 01:16 PM
TealCivic93's Avatar
Default Re: balljoints (blacklist96)
im going to change my both my front ball joints, anything else that would be good to change while i'm there?
Pancho2193
Mar 11, 2011 05:10 PM
PatrickGSR94
Suspension & Brakes
18
May 12, 2010 09:55 AM
s2000_nur
24
Aug 4, 2005 06:11 PM
Flamenco-T
Aug 21, 2002 11:49 PM
senpai
Aug 17, 2002 02:06 AM
