oil leak where is it coming from????
Old Jan 7, 2005 | 03:17 PM
messeduprex's Avatar
Default oil leak where is it coming from????
ok i have a obd 1 zc i'm trying to get everything straight befor i do a turbo i vahe a leak on the left side(tranny side) front it's not coming from the valve cover or the head gasket i had to remove the cam seal to put in the cam angle sensor i pulled it out and it dosent seem to be leaking from there either o-ring looked fine no oil in the groove any place else it could be leaking from? it's not leaking alot just enough to **** me off that i have a dirty motor
Old Jan 7, 2005 | 06:40 PM
fourthgenhatchB17's Avatar
Default Re: oil leak where is it coming from???? (messeduprex)
Check the distributor O ring.
D Griff
Nov 14, 2009 09:01 AM
danielblushtein
Mar 16, 2009 12:33 PM
98GreenTegGSR
Dec 18, 2006 11:56 PM
92TEGGYGSR
Jun 3, 2004 06:42 PM
slowpokesi
Jan 27, 2003 08:26 AM
