Bullsh!t Theory? Does Thicker oil Make V-tec Sound louder!!
Old Jan 7, 2005 | 01:49 PM
1SickHb's Avatar
Default Bullsh!t Theory? Does Thicker oil Make V-tec Sound louder!!
I Dont THink So!!! , But my Friends EK Hatch Wit A B16, sounds Crazy and he saids its because of the oil!!
Old Jan 7, 2005 | 02:41 PM
PrettyLude's Avatar
hahahahaha
Old Jan 7, 2005 | 02:46 PM
mattssi's Avatar
Wow. I have now heard it all.
Old Jan 7, 2005 | 02:54 PM
DIFFUT'S INC.'s Avatar
Default Re: (mattssi)
lol ok.....
Old Jan 7, 2005 | 03:41 PM
Mikey's Avatar
Default Re: (DIFFUT'S INC.)
Put in 50 weight oil and I'm sure your engine will make noises much louder than vtec. Your rods will thank your bearings on the way outside of the block.
Old Jan 7, 2005 | 03:42 PM
NJIN BUILDR's Avatar
Default Re: Bullsh!t Theory? Does Thicker oil Make V-tec Sound louder!! (1SickHb)
It's a lot quieter without oil
Glenn
Old Jan 7, 2005 | 04:24 PM
96MidoriHatch's Avatar
Default Re: Bullsh!t Theory? Does Thicker oil Make V-tec Sound louder!! (NJIN BUILDR)
As stupid as it sounds I do remember a few posts in the past from people claiming that they changed their oil and vtec was louder. Personally, I think its all in their mind.
EDIT: I found this one
https://honda-tech.com/zerothread?id=435169
Old Jan 8, 2005 | 01:40 AM
sleeperb16a's Avatar
In theory, I think it should be quieter because of the thicker film of oil between moving parts.
However, on my B16a, I have experienced that, with the valve lash on the looser side, the vtec note is definitely louder and the transition into vtec mode is also more pronounced...big surge of power.
After tightening up the valve lash, the vtec sound is very muted and the car keeps pulling smoothly and strongly all the way to the redline without a dramatic power jump at the vtec engagement point.
The car was quicker by a tenth with the tighter valve lash.
Old Jan 8, 2005 | 07:56 AM
jdm420da6's Avatar
Default Re: Bullsh!t Theory? Does Thicker oil Make V-tec Sound louder!! (sleeperb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperb16a &raquo;</TD></TR><TR><TD CLASS="quote">In theory, I think it should be quieter because of the thicker film of oil between moving parts.
The car was quicker by a tenth with the tighter valve lash.</TD></TR></TABLE>
i can see what u mean about the valve lash thing, when i put my itr cam in my motor i noticed when the valve lash was looser, vtec was louder, in my theory its because of the "looseness" of the valves and the clicking is just way louder in vtec creating a louder tone. when i tightened my valves it got a little quieter. and the motor ran way smoother, especially at engagement point.
Old Jan 8, 2005 | 12:42 PM
MrTodd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SickHb &raquo;</TD></TR><TR><TD CLASS="quote">Bullsh!t Theory? Does Thicker oil Make V-tec Sound louder!!
I Dont THink So!!! , But my Friends EK Hatch Wit A B16, sounds Crazy and he saids its because of the oil!!</TD></TR></TABLE>
Your friend doesn't know what he's talking about. As long as there's enough oil pressure to activate the locking pins, vtec will engage normally just like every other time. Changing the oil viscosity isn't going to make any difference in the vtec engagement noise increase. As stated above, thicker oil would only quiet things down (such as valve tap, not exhaust tone.) if anything.
Unless his locking pins weren't all fully engaging, changing the oil to a thicker viscosity wouldn't make any difference. Even so, a thicker oil probably wouldn't make a slugded up locking pin suddenly work again either...
Patch
Jan 3, 2020 06:55 PM
integrawow
Dec 6, 2009 04:58 PM
BLU CIVIC
Dec 4, 2008 04:41 AM
tuan...
May 7, 2008 12:09 PM
B18C-YA!
28
May 2, 2006 10:52 AM
