d16y7 turbo on d16y8
Old Jan 7, 2005 | 10:35 AM
fivelugsteelies's Avatar
Default d16y7 turbo on d16y8
I am currently look to buy a 98dx hatch with a turbo on it. I was told the turbo is similar to the greddy kit. Would I be able to swap the motor for a y8 and keep the turbo kit without modifying it. Or would I be better off doing a mini me. Thanks in advance.
Old Jan 7, 2005 | 10:54 AM
eK9aT10pSi's Avatar
Default Re: d16y7 turbo on d16y8 (fivelugsteelies)
you'd have to redo the upper charge piping from the IC to the TB. you'd need the ecu, wire up the vtec, etc. if the bottom end is still good, do a minime, much cheaper and essentailly does the same ****.
codyb13
Jun 22, 2005 04:07 PM
00_whytehatch
14
Apr 27, 2005 09:32 PM
TurboHatch00
Sep 15, 2004 06:49 PM
Irishweird00
Mar 14, 2003 10:32 AM
clean
Nov 19, 2001 02:13 AM
