Wierd scraping noise when cold
Old Jan 7, 2005 | 09:03 AM
The Phil's Avatar
Default Wierd scraping noise when cold
When i'm pulling out of my neighborhood, there is a change in incline of the ground i'm driving on (it starts out going downhill, then the main road is flat), if i go too fast (anywhere over like 10mph) turning left, i hear a scraping sound from the front right area of my car. It never happens if i'm turning to the right. My car isn't lowered or anything, and i only noticed it happening when its cold outside. Any ideas?
Old Jan 7, 2005 | 10:48 AM
Eddiebx's Avatar
jack up ur car, and take off the drivers side rim, and look around for where it might have been makign contact, thtas a good place to start looking
Old Jan 7, 2005 | 03:08 PM
Prolink's Avatar
Default Re: Wierd scraping noise when cold (xthephilx)
Check both sides. Check the rotor dust cover, cv joints, brakes, tires and wheel well.
Old Jan 7, 2005 | 06:53 PM
The Phil's Avatar
Default Re:
nvm about it being only when its cold...it just happened when i was pulling up to my house. I'm going to take the wheel off tomorrow morning and try to look around...thanks
Old Jan 7, 2005 | 07:33 PM
MackDad's Avatar
Default Re: Re: (xthephilx)
I had the same problem and it turned out to be a heat-shield under the car rubbing on the exhaust which made a funny grinding/scraping noise. It took me months to figure it out..lol
Old Jan 8, 2005 | 07:12 PM
funkmasterchipz's Avatar
Default Re: Re: (MackDad)
is it like a creaking noise when ur ascending stairs in a house? or is it like metal on metal? becuase it could be ur struts going really bad if its the creaking and if its not its probably your brake dust guards
Old Jan 9, 2005 | 09:53 AM
The Phil's Avatar
Default Re: Re: (funkmasterchipz)
its not metal on metal...it sounds like something is hitting the ground...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackDad &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem and it turned out to be a heat-shield under the car rubbing on the exhaust which made a funny grinding/scraping noise. It took me months to figure it out..lol</TD></TR></TABLE>
haven't gotten around to jacking my car up...i'll try to do that next week
rspdron
Honda Civic (2001 - 2005)
Apr 19, 2011 07:46 PM
shawndb1
Aug 23, 2007 04:33 PM
bpetruzzo
11
Aug 20, 2005 02:54 PM
tdc
Jun 29, 2003 05:57 PM
Chip398193
Jul 27, 2001 10:54 PM
