IAT sensor
Old Jan 7, 2005 | 08:40 AM
sleeperb16a's Avatar
Default IAT sensor
Are OBD0 and OBD1 IAT sensors the same? Can they be substituted?
Also, any advantage of relocating the IAT sensor from the intake runner (OBD0) to the air intake tube right after the filter?
TIA
Old Jan 8, 2005 | 01:28 AM
Default Re: IAT sensor (sleeperb16a)
bump;
Old Jan 9, 2005 | 12:38 AM
Anyone?
Old Jan 9, 2005 | 03:48 AM
hondaguyef's Avatar
I have an OBD0 IAT on my car (92' SI). The sensors themselves function the same. I wouldn't recommend moving the sensor from the intake runner. I am sure the engineers at Honda have it positioned there for a reason.
Phil
Old Jan 9, 2005 | 10:09 AM
Default Re: IAT sensor (hondaguyef)
Glad to know that OBD0 and OBD1 IAT sensors can be swapped....coz the spare sensor that I have is from an OBD1.
Just for argument's sake, the IAT location was changed from the intake runner to the intake tube by Honda itself on later models. Is it possible that the intake runner location is more succeptible to heat soak?
Thanks hondaguyef!
Old Jan 9, 2005 | 10:19 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperb16a &raquo;</TD></TR><TR><TD CLASS="quote"> the IAT location was changed from the intake runner to the intake tube by Honda itself on later models.
Yeah, I realized this after I made my first statement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperb16a &raquo;</TD></TR><TR><TD CLASS="quote"> Is it possible that the intake runner location is more succeptible to heat soak?</TD></TR></TABLE>
You're probably right. A more accurate reading of the actual Air temp. instead of an Engine/ Air temp mix.
Thanks hondaguyef!</TD></TR></TABLE>
No problem .
Phil
Old Jan 9, 2005 | 11:23 AM
eda6's Avatar
You can also use obd2 iat sensors on obd0 and obd1 manifolds.
Old Jan 10, 2005 | 12:07 AM
Default Re: IAT sensor (eda6)
So OBD2 IAT sensors can also be substituted. Shall save this info.
Tks eda6!
Old Jan 10, 2005 | 07:39 AM
ImportechPerformance's Avatar
Ha! I didnt even think that an OBD 0 ecu read IAT.
Diversion
Jul 21, 2009 11:57 AM
SuicideSlide
May 7, 2005 01:35 PM
SixguN
Mar 4, 2005 11:34 AM
supernova
Dec 3, 2001 06:49 AM
