88-91 crx k motor info
Old Jan 7, 2005 | 07:59 AM
DELSLOWEST's Avatar
Default 88-91 crx k motor info
i need so more info on putting a k motor in a 89 crx
..wiring harness does it jsut plug in or do you have to splice into the wires
..motor mounts cut and welding
..halfshafts? what kind or does somebody make some to fit
..the shift linkage or cable? what do i use
..header use the stock one or aftermarket?
..what ecu and does anything need to be done to the ecu?
..any other info would be nice too little hints anything that you did to your rex to help me out
thanks for your time
later
Old Jan 7, 2005 | 08:06 AM
DELSLOWEST's Avatar
Default Re: 88-91 crx k motor info (DELSLOWEST)
bump so i can put this k in my car
Old Jan 7, 2005 | 08:54 AM
DELSLOWEST's Avatar
anybody have any kind of info?
plez
Old Jan 7, 2005 | 09:41 AM
DELSLOWEST's Avatar
bump
Old Jan 7, 2005 | 12:36 PM
fabworxs's Avatar
There is a bunch on info on this swap you just need to search for it. To answer some of your ????'s
1. HASPORT is making a motor mount kit but it WILL include a weld-in mount.
2. You'll need to purchase an aftermarket header to clear the firewall.
3. You need a KPRO
4. Wiring harness for plug & play install will be provided by HASPORT $350 range.
5. HASPORT will offer axles for the swap...$300 range.
6. HINTS...
Be ready to buy a new hood!
Old Jan 10, 2005 | 07:00 AM
DELSLOWEST's Avatar
Default Re: 88-91 crx k motor info (fabworxs)
what is a kpro?
and what ecu do i use
later
Old Jan 10, 2005 | 08:12 AM
6SPD_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELSLOWEST &raquo;</TD></TR><TR><TD CLASS="quote">what is a kpro?
later</TD></TR></TABLE>
K-pro is hondata's reprogramming of the stock ECU (PRB=k20a2 PRC=jdm K20a type R)...K-pro is fully programmable...including cam angles (the "i" in i-vtec)
hope you have atleast $8000...I am up over $10,000 & don't even have it installed yet
search - its all be covered before you'll need everything for a EG/EK/DC + more
Old Jan 13, 2005 | 12:28 PM
DELSLOWEST's Avatar
Default Re: 88-91 crx k motor info (adirondackR)
bump for more info
plez
Old Jan 13, 2005 | 12:38 PM
6SPD_EK's Avatar
to my knowledge only hasport & Pacman has done this swap since there are NOT mounts out yet available to the public...until that happens I don't know how much info you expect to get
91c-rex_si
14
Mar 27, 2011 08:07 PM
7thgenRS
Oct 14, 2007 06:07 AM
BishopXIII
Dec 20, 2005 06:10 PM
DELSLOWEST
64
Feb 5, 2005 01:06 PM
jsteezy1290
52
Feb 22, 2004 12:01 PM
