Anyone use a mechanical fuel pressure gauge in car? Too unsafe?
Old Jan 8, 2002 | 08:16 PM
HX_Guy's Avatar
Default Anyone use a mechanical fuel pressure gauge in car? Too unsafe?
I know people run mechanical oil pressure into the cabin with no problem...can fuel pressure be ran also? I dont really see how burning hot oil is any safer then fuel.
Old Jan 8, 2002 | 08:25 PM
earl's Avatar
Default Re: Anyone use a mechanical fuel pressure gauge in car? Too unsafe? (HX_Guy)
I think it's more about igniting the gasoline inside the car than hot burning oil on your feet.
Old Jan 8, 2002 | 08:26 PM
HX_Guy's Avatar
Default Re: Anyone use a mechanical fuel pressure gauge in car? Too unsafe? (earl)
Why would the gasoline ignite? Oil ignites as well, granted not as easily..but it does...no?
Old Jan 8, 2002 | 09:38 PM
nfn15037's Avatar
Why not just get an electric guage? Probably much safer, but i dont think as accurate.
Old Jan 9, 2002 | 04:52 AM
Mista Bone's Avatar
D Tranny Guru
Guess you want beat down with the big ugly stick!
Gasoline will flash burn 20 times easier that engine oil.
Good news, get a short sweep fp setup from Autometer for about $70. No need for the $200 electronic setup.
Also might wanna look into Nordskog gauges.
Old Jan 9, 2002 | 05:01 AM
Red Civic T's Avatar
New User
Default Re: Anyone use a mechanical fuel pressure gauge in car? Too unsafe? (Mista Bone)
I run mechanical, and it IS safe. Fuel does not come in the cockpit as there is a diaphragm in the line on the motor side of firewall. I use a metal fuel line connector courtesy of a buddy in the Metro bus system...
Old Jan 9, 2002 | 05:05 AM
Salami's Avatar
Yeah the only safe way is to run the diaphram. My friend tried it on his car and had a pain in the *** time trying to get it to work right though. Also NHRA rules don't allow fuel lines in the car for this same reason. If you ever had an accident and the fuel line got cut, would you be willing to guess at the results?
[Modified by Salami, 9:08 AM 1/9/2002]
Old Jan 9, 2002 | 06:42 AM
HX_Guy's Avatar
Hmm...the short sweep doesnt seem accurate enough..I meant it does from like 0 - 25 - 50 - 75...I would think its hard to tell a differance between 35 and 40 PSI
Old Jan 9, 2002 | 07:28 AM
sgT's Avatar
sgT
Default Re: Anyone use a mechanical fuel pressure gauge in car? Too unsafe? (Salami)
They make an isolator for 100psi?
I've only seen and heard of isolators for carbs that go up to 15psi.
Old Jan 9, 2002 | 03:44 PM
New User
Default Re: Anyone use a mechanical fuel pressure gauge in car? Too unsafe? (sgT)
Well, against the FP reading @ the Honda dealer I think it was about 3-4 lbs. off at idle. Should run it off in a little bit more scientific manner though....That is a good question - can you ever believe a number when you see it - better check all you can.
Old Jan 10, 2002 | 03:15 AM
Mista Bone's Avatar
D Tranny Guru
then check into Nordskog Digital gauges.
BTW My 86 TA has a nice red lit gauge cluster, guess which I'll be using?
http://www.nordskogperformance.com/m8034.html
[Modified by Mista Bone, 7:19 AM 1/10/2002]
Old Jan 10, 2002 | 09:21 AM
sgT's Avatar
sgT
looks like cyberdyne
Old Jan 11, 2002 | 04:42 AM
Mista Bone's Avatar
D Tranny Guru
Nordskog is the original, Cyberdyne might be using their products.
Happens more than you think!
lude98SH
Jan 10, 2008 05:21 PM
ekim952522000
Sep 28, 2006 05:13 AM
Drew Peacock
Dec 11, 2004 05:46 PM
Pfieff
Jun 19, 2003 10:49 AM
symba
Aug 14, 2002 03:45 PM
