IF had to get 1 of 3 which would you get? SS Valves, Springs, or Retainers.. On LS,13-16PSI, and sto
Old Jan 8, 2002 | 08:08 PM
DamonBoost's Avatar
New User
Default IF had to get 1 of 3 which would you get? SS Valves, Springs, or Retainers.. On LS,13-16PSI, and sto
I am rebuilding my head. It has 150K on it and I cant afford to get Valves, Retainers, and Springs so I am only going to get the one I need the most for my application. I hear the honda valve train is very good anyway. I never plan to raise my redline from stock and I plan on boosting 13psi on the street and 16 at the track. Head Reliabilty and Longevity is what is important to me. Thank you
Old Jan 8, 2002 | 09:04 PM
sparkz's Avatar
Default Re: IF had to get 1 of 3 which would you get? SS Valves, Springs, or Retainers.. On LS,13-16PSI, and
If you only had to pick just one, SS valves. But I suggest you should save up a lil more and get everything installed at once. Most likely you'll probably end up upgrading those items too
Old Jan 8, 2002 | 09:21 PM
DIRep972's Avatar
Smarter than you
just get a stock head for like 150 like I told u.. Build it up later when u can afford it! ***!
Old Jan 9, 2002 | 06:02 AM
Doodoo's Avatar
Be sure you get ALL STOCK HONDA seals and such for the head. I went through three down times with aftermarket crap on my head.
With the valves, retainers and springs...I would save and get them all. Or at least springs and retainers. Good luck.
Old Jan 9, 2002 | 06:06 AM
ekb18c's Avatar
IF i were you, i would just save up enough money for everything. Its better to it right once, rather then do a half *** job and then have to redo it again.. Dont rush. Just be calm and use your head. Save up and do everythign at once. I have done half *** job before and then i had to redo it all over again, which cost me more money at the end.
Old Jan 9, 2002 | 06:48 AM
Seraph0's Avatar
I'd do SS valves on the exhaust side. You don't need stiffer springs or lighter retainers if you are not going to raise the redline.
Old Jan 9, 2002 | 06:55 AM
TurboSedan's Avatar
New User
The valves are best for the first thing, but if you get them all it will have a greater benefit.
98integralsB18
Apr 19, 2012 10:36 AM
mobile chernobyl
Aug 8, 2008 12:36 PM
herde1724
Jan 27, 2005 11:41 PM
quick1racer
Jul 14, 2004 05:40 PM
Trajic
Jul 4, 2001 01:13 PM
