Honda Fit/Jazz wiring Diagram
I got part of this diagram but need to find the wire for the power of the fuel pump to install alarm/immobilizer. Anyone knows where i can find this? The negative door trigger switch and handbrake switch cable location would also be useful.
Thanks
Modified by quacka at 7:23 PM 1/8/2005
Modified by quacka at 7:35 PM 1/8/2005
Thanks
Ok I found teh fuel pump but the remote start refuse to work. It seems like it doesn't want to pump the fuel without teh key in. Maybe it has an immobilizer. Anyone know how to bypass this?
I need urgent help finding the Power unlock and Power lock. Spent two days going through all the cables with a test light. Nothing unlocks or lock the door. Please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quacka »</TD></TR><TR><TD CLASS="quote">Ok I found teh fuel pump but the remote start refuse to work. It seems like it doesn't want to pump the fuel without teh key in. Maybe it has an immobilizer. Anyone know how to bypass this?
</TD></TR></TABLE>Link http://www.bulldogsecurity.com
94
94
In the 2001-2004 Honda Civic they are white/blue lock and white/green unlock and they are neg. (-) trip, about a 250mA 1/4 sec. pulse, most remote starts and alarms will have at least that, and they can be found in a gray plug above the drivers kickpanel.
If the remote starts works if you put the key in the ign., [without turning it on] but will not work if the key is not in the ign. then you have a transponder key immobilizer, it turns off the injectors, if the key is not in the ign., you will need to get a bypass mod. what is the model and year of your car
94
94
katiejoy
Jul 24, 2014 11:33 AM
streetsold6teeny8
11
Aug 6, 2006 07:24 PM
