auto to manual wiring help....reverse lights!!!
Old Jan 6, 2005 | 09:32 PM
s73's Avatar
s73
New User
Default auto to manual wiring help....reverse lights!!!
Ok.....i am in the process of installing my ecu....
there are 4 ecu plugs on the auto trans......i know that i need to take out a few wires from plug B (the plug that is only found on the auto ecu)......i suppose to connect the green wire w/ black strip and a yellow wire from the auto shifter plug......to the same color wires that i de-pinned from auto ecu plug B...
Here is the problem....on ecu plug B, i found 2 yellow wires and 2 green w/ black strip.....????????
anybody ever done this swap in the past, please drop me a msg.....thanks a lot
ps...its a 97 ex auto to manual....
Old Jan 6, 2005 | 09:36 PM
murmur9's Avatar
Default Re: auto to manual wiring help....reverse lights!!! (s73)
bump for you....i will need to know soon.
btw sorry to post *****....but would you mind posting the links to everything your using to do the auto to manual yourself? tia
bump....
Old Jan 6, 2005 | 10:51 PM
s73's Avatar
s73
New User
Default Re: auto to manual wiring help....reverse lights!!! (murmur9)
sure man.....best write up i have found .... by Brooksto:
http://sohchonda.com/ipw-web/b...=3418
what car are u going to do the auto to manual swap? Its A LOT of work....i have done motor swaps in the past, and to me, the auto to manual swap is harder....
if u have any questions about the swap just ask.....i am almost done with my swap ***knock on wood***
if u are doing it in an ek.....feel free to ask me....i had done A LOT of research on this topic
Old Jan 7, 2005 | 02:09 AM
thegreek's Avatar
Old Jan 7, 2005 | 09:47 AM
s73's Avatar
s73
New User
bump
Old Jan 7, 2005 | 10:04 AM
ralphie14's Avatar
I think your best bet would be to simply find an manual ECU. My roommate has the auto-manual swap done on his hatch and and we wired mine exactly the same when we replaced the chasis harness becuase I was able to get an auto harness for $10 thanks to the lack of knowledge the local salvage yard has It is not that hard to wire the actual harness but as for the ECU I already had a manual ECU and my roommate just went and got one when he did his swap. I am not sure the info is really helpful in your situation but it would be the easiest way to do it but not the cheapest.
PS if I remember right too to use an automatic ECU on a manual you need to change a jumper in the ECU but I could be wrong.
Old Jan 7, 2005 | 10:11 AM
Patron's Avatar
Default Re: auto to manual wiring help....reverse lights!!! (ralphie14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralphie14 &raquo;</TD></TR><TR><TD CLASS="quote">I think your best bet would be to simply find an manual ECU. My roommate has the auto-manual swap done on his hatch and and we wired mine exactly the same when we replaced the chasis harness becuase I was able to get an auto harness for $10 thanks to the lack of knowledge the local salvage yard has It is not that hard to wire the actual harness but as for the ECU I already had a manual ECU and my roommate just went and got one when he did his swap. I am not sure the info is really helpful in your situation but it would be the easiest way to do it but not the cheapest.
PS if I remember right too to use an automatic ECU on a manual you need to change a jumper in the ECU but I could be wrong.</TD></TR></TABLE>
Ok smarty pants, convert these 2 ecu's on my desk to manuals and lets finish that swap!
Old Jan 7, 2005 | 10:13 AM
ralphie14's Avatar
Default Re: auto to manual wiring help....reverse lights!!! (ptran13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran13 &raquo;</TD></TR><TR><TD CLASS="quote">
Ok smarty pants, convert these 2 ecu's on my desk to manuals and lets finish that swap! </TD></TR></TABLE>
I didn't say I knew how to do it I said I thought it needed to be done now tell your girlfriend to come over and make some pie!
Old Jan 7, 2005 | 10:14 AM
Patron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralphie14 &raquo;</TD></TR><TR><TD CLASS="quote">I didn't say I knew how to do it I said I thought it needed to be done now tell your girlfriend to come over and make some pie!</TD></TR></TABLE>
haha, yeah right, she's not domesticated.
Old Jan 7, 2005 | 10:19 AM
ralphie14's Avatar
haha, yeah right, she's not domesticated.</TD></TR></TABLE>
Time to upgrade
Old Jan 7, 2005 | 12:10 PM
s73's Avatar
s73
New User
I think maybe i was no so clear on what i wrote....
i am installing a manual ecu, i just have some questions about wiring in the reverse lights:
when u change to a manual ecu u need to change some pins in ecu plug A....(thats if u did the IACV fix....change from a 3 wire iacv to a 2 wire iacv)
still need to know how to wire in the reverse lights.....i know if all else fails....i can alway just wire it stright to the reverse light switch on the tranny.....but i have heard that there is a way to run some wires from ecu plug b (the one that is only found on on an auto)....to part of the auto shifter plug.....
thanks for replying guys
TheLastSpartan
15
Dec 4, 2022 12:42 PM
Killercocopuff
Oct 17, 2011 07:55 AM
civic_ceze
Honda Civic (2001 - 2005)
Nov 2, 2009 06:55 PM
s73
Jan 7, 2005 12:12 PM
s73
Jan 7, 2005 09:47 AM
