anyone ever heard of a witness mark
Old Jan 6, 2005 | 07:55 PM
ej1 pilot's Avatar
Default anyone ever heard of a witness mark
after my t belt install on my jdm d15b i put the cam gear at tdc then i was looking for the mark on the crank pully and all that was there was a little W engraved...my friend said it stand for witness mark which is what you line it up to....anyone heard this? i just dont want my motor to blow up soon as i get it started...TIA
Old Jan 6, 2005 | 08:01 PM
snatch's Avatar
Default Re: anyone ever heard of a witness mark (Art In Motion)
On mine there was a pointer on the crankshaft, and then a mark on the oil pump to line it up to. Never heard of a witness mark.
Old Jan 6, 2005 | 08:20 PM
ABK's Avatar
ABK
Default Re: anyone ever heard of a witness mark (******)
put your crank pulley on and line it up at the white mark all by itself
Old Jan 6, 2005 | 08:23 PM
ej1 pilot's Avatar
Default Re: anyone ever heard of a witness mark (ABK)
no white mark thats my point
Old Jan 6, 2005 | 08:49 PM
ABK's Avatar
ABK
no marks on your crank pulley? at all nothing, not even notches
If not time to get a new pulley because I have no idea how you are going to time your car.
Old Jan 6, 2005 | 08:54 PM
lohatch's Avatar
there should be 3 marks real close to each other looking something like this( ||| ), and then one single one by itself which is what you line up with the pointer on your plastic cover. this isnt on your crank pulley???
Old Jan 6, 2005 | 09:11 PM
ej1 pilot's Avatar
Default Re: anyone ever heard of a witness mark (lohatch)
yeah im pretty sure its not all i see is a W...is it on the top of the crank pully or the flat surface thats parallel to the motor?
Old Jan 6, 2005 | 10:08 PM
snoochtodanooch's Avatar
their is a white mark on the pulley, and there is an etch in the shaft itself if you take the pulley off. Either will work.
Old Jan 6, 2005 | 10:10 PM
NathanMorris's Avatar
Default Re: anyone ever heard of a witness mark (snoochtodanooch)
not sure about the W, but I'm with the guy above...
maybe we could get a picture of what you're seeing?
- Nathan
Old Jan 7, 2005 | 12:30 PM
ej1 pilot's Avatar
Default Re: anyone ever heard of a witness mark (92Lx)
ill try to get my friend to snap it with his digicam but ill probly be starting it today...crossing my fingers
Old Jan 7, 2005 | 07:50 PM
ABK's Avatar
ABK
here just do this, put a screw driver or something really really long into a #1 spark plug hole and rotate it by hand do not crank it. And look for a place where the screw driver or whatever you put in there sticks up the most. That's your TDC.
halocore
Apr 1, 2009 06:11 PM
RTW DC2R
May 23, 2005 10:33 AM
Nextelbuddy
Mar 29, 2004 11:43 AM
TurboBumblBee
May 24, 2003 10:19 AM
Luserkid
Mar 29, 2003 02:41 PM
