Inline Pro Manifold Wastegate fitment?
Old Jan 6, 2005 | 03:38 PM
StolenTeg's Avatar
Default Inline Pro Manifold Wastegate fitment?
That wastegate flange look as if it would fit a 35/38mm tial wastegate but im not sure because the shape look kind of weird. The manifold also have rust on it, is there anyway i can get the rust off and keep them off?
Old Jan 6, 2005 | 03:42 PM
hondaguyef's Avatar
Default Re: Inline Pro Manifold Wastegate fitment? (StolenTeg)
Yeah, That's a 35/38mm flange. As for the rust, take a wire wheel to it. If you don't have access to one just get some finer grit sandpaper and remove all of the rust by hand. After all of the rust is gone coat it w/ a high temp enamel. I have some that is good to like 1500 degrees or so. I am in the same boat and that is what I will be doing.
Phil
Old Jan 6, 2005 | 03:47 PM
86si's Avatar
sand blast it
Old Jan 6, 2005 | 04:13 PM
StolenTeg's Avatar
Default Re: Inline Pro Manifold Wastegate fitment? (86si)
Cool, I can get those 1500 Degree engine paint but are they good enough. I have a feeling they will crack off when the manifold get too hot?
InTraining124
Oct 19, 2008 05:22 PM
AutoLab
Jun 30, 2007 07:15 PM
Dc4turbo408
Welding / Fabrication
31
Jul 8, 2006 08:50 PM
IntegraMastaz
Feb 8, 2006 09:33 AM
f1 vtec
Apr 29, 2004 04:53 AM
