f22 header on h22?
Old Jan 6, 2005 | 02:52 PM
allshowaccord91's Avatar
Default f22 header on h22?
i have a DC header on my 91 'cord f22a1 ...that should directly bolt up to the h22 right? thanks
Old Jan 6, 2005 | 02:53 PM
Luisito825's Avatar
Default Re: f22 header on h22? (allshowaccord91)
they are different.
Old Jan 6, 2005 | 03:01 PM
Default Re: f22 header on h22? (ogbusboy)
can i get more info about being different... do u mean it absolutely wont work???
Old Jan 6, 2005 | 03:24 PM
SpeedFreak77's Avatar
First off you should have done a search because this is asked over and over again but no big deal. To answer your question they are a different bolt patter, the F22 looks like this, o o o o The H22 like this: o oo o when comparing the two and unfortunatly it won't work at all.
Old Jan 6, 2005 | 06:38 PM
PrettyLude's Avatar
correct
Old Jan 6, 2005 | 06:41 PM
Default Re: (PrettyLude)
man that sucks...thanks for the input though!
Old Jan 6, 2005 | 07:56 PM
Stew Pidasso's Avatar
Default Re: f22 header on h22? (SpeedFreak77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedFreak77 &raquo;</TD></TR><TR><TD CLASS="quote">First off you should have done a search because this is asked over and over again but no big deal. To answer your question they are a different bolt patter, the F22 looks like this, o o o o The H22 like this: o oo o when comparing the two and unfortunatly it won't work at all.</TD></TR></TABLE>
Other way around
Old Jan 7, 2005 | 04:36 AM
TOAB's Avatar
actually hes right. the f22a's are evenly spaced, the f22b's had the inner ports all scrunched.
Old Jan 7, 2005 | 07:19 PM
gaydm.accord's Avatar
Default Re: (TOAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOAB &raquo;</TD></TR><TR><TD CLASS="quote">actually hes right. the f22a's are evenly spaced, the f22b's had the inner ports all scrunched.</TD></TR></TABLE>
h22 = o o o o f22b= o oo o
Modified by gaydm.accord at 12:16 AM 1/8/2005
Old Jan 7, 2005 | 08:49 PM
AVcTcEoCrd's Avatar
Default Re: (gaydm.accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">
h22 = o o o o f22= o oo o
correct
incorrect
Old Jan 7, 2005 | 09:24 PM
ACC0RD22's Avatar
Default Re: (AVcTcEoCrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVcTcEoCrd &raquo;</TD></TR><TR><TD CLASS="quote">
correct
incorrect </TD></TR></TABLE>
actually your wrong, if you had read TOABs post you would know that f22a - o o o o and f22b o oo o and h22 - o o o o dont flame unless you have your facts striaght, if you want further proof of teh f22 differences ill go down to where my 94 is stored and take the heat shield off take a pic, and take the heatshield off my 90 and take a pic and show you the difference. actually your only half wrong, the h22 pattern on the second post is wrong but the f22 is right if they are speaking iof the f22a
Old Jan 7, 2005 | 10:25 PM
Carolina Fried Rice's Avatar
Default Re: (ACC0RD22)
this is such a popular topic, it should have its own forum.
Old Jan 7, 2005 | 11:17 PM
i edited mine. i can speak on behalf of the h22a and the f22b cuz i've tried them both and those do not work. as for the f22a i cannot yet speak for.
Old Jan 8, 2005 | 07:05 AM
AVcTcEoCrd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACC0RD22 &raquo;</TD></TR><TR><TD CLASS="quote">
actually your wrong, if you had read TOABs post you would know that f22a - o o o o and f22b o oo o and h22 - o o o o dont flame unless you have your facts striaght, if you want further proof of teh f22 differences ill go down to where my 94 is stored and take the heat shield off take a pic, and take the heatshield off my 90 and take a pic and show you the difference. actually your only half wrong, the h22 pattern on the second post is wrong but the f22 is right if they are speaking iof the f22a</TD></TR></TABLE>
first off, i have both motors, f22b and h22a, 1 sitting around and 1 in my car. even if the f22a is o o o o, it wont fit on a h22 head anyways.
Old Jan 8, 2005 | 09:05 AM
ACC0RD22's Avatar
why is that, the spacing is the same, the only thing i can think of that would make it not fit is an incorrect bolt pattern.
Old Jan 9, 2005 | 04:00 PM
JDM_CD7's Avatar
Can the lower portion of the F22B1 (VTEC) Header be used on the Top portion of the JDM H22 Header?
I would think so since they are both 4-2-1?
TIA
Old Jan 9, 2005 | 04:07 PM
fw190bvi's Avatar
Default Re: (JDM_CB7)
but the lower portion of the 2 piece H22 header is just as good if not better
Old Jan 10, 2005 | 07:23 PM
JDM_CD7's Avatar
Let me rephrase that: Can the lower portion of the F22B1 (VTEC) Header be used WITH the Top portion of the JDM H22 Header?
Thanks
Old Jan 10, 2005 | 10:49 PM
TOAB's Avatar
it might... i think the diameter on the h half would be a bit bigger... so maybe they wont line up quite right.
and for the spacing crap earlier, F22A's have evenly spaced ports... the F22Bx's have the scrunched center ones. if all f22'a were o oo o 4th gen people wouldnt be able to use 1g eclipse turbo manifolds.
Old Jan 14, 2005 | 01:17 PM
Default Re: (TOAB)
No it won't work I tried it the H22 is bigger than teh F22
Old Jan 14, 2005 | 06:24 PM
ACC0RD22's Avatar
Default Re: (SpeedFreak77)
isnt that the point of getting aheader in the first place?is the flange bigger??? please elaborate
Old Jan 14, 2005 | 10:06 PM
SPEED FoRCE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACC0RD22 &raquo;</TD></TR><TR><TD CLASS="quote">why is that, the spacing is the same, the only thing i can think of that would make it not fit is an incorrect bolt pattern. </TD></TR></TABLE>
the flanges are different.
manueel423
Mar 21, 2017 06:21 AM
H23vtecEF
Jan 18, 2013 03:59 PM
slowaccord559
Oct 22, 2008 07:22 PM
EK9-Stealth
Oct 23, 2007 11:07 PM
509MTRS
Mar 23, 2004 12:50 PM
