Help with air/fuel installation
Old Jan 6, 2005 | 11:10 AM
Del$olB16A3's Avatar
Default Help with air/fuel installation
I'm sure this is pretty easy, but can someone help me out on how to install a air/fuel gauge on a b16a3...Thanks
Old Jan 6, 2005 | 12:23 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Help with air/fuel installation (Del$olB16A3)
Find the primary O2 sensor (one closest to headers) and splice and solder into the white wire. That is your signal wire going into your A/F gauge itself. Look inside the under-dash fuse box and you'll find 5 ports with male taps in it. Number 5 port is your 12v ACC power. Using a male spade connector, connect the power wire from the gauge to this port. Lastly, take the remainder wire (ground) to a good bolt hole and ground it (ring connector) with a corresponding bolt (10mm). Waahlah!...your A/F should glow up once you put your keys in ignition/ACC. Make sure all your connections are good and soldered points are wrapped with electrical tape.
92prelude23
Nov 17, 2008 02:09 PM
si_motor_spt
Jul 14, 2008 09:36 AM
bmiller17
Jan 24, 2006 02:32 PM
93IntegraRacer
Feb 10, 2004 07:23 PM
Tad
23
Nov 13, 2003 11:24 AM
