AFC problem
Old Jan 6, 2005 | 01:24 AM
PHILLIPDEEZ's Avatar
Default AFC problem
i have a Cx with a d16z6 swap i recently found a Vafc for 100 and decided to bust a DIY since im tryin to learn my question is that my car is throwing codes 21 and 22 im sure its cause of the Vafc but why is it cause i had to ut the VTM cause the vtec wiring goes through the controller before it hits the ECU as well as the motor
Old Jan 6, 2005 | 01:27 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: AFC problem (PHILLIPDEEZ)
did you follow the wiring diagram correctly? when you wire it, i believe you're suppose to cut the VTM (blue wire if i remember correctly) and hook up one end while you leave the other end hanging.
CpRiCe87
Feb 11, 2006 11:42 AM
i v o u s
Apr 5, 2005 08:50 AM
noricercrx
May 6, 2002 08:18 PM
JoshRambo
Jul 31, 2001 08:24 PM
