E-brake light stays on
Old Jan 5, 2005 | 10:03 PM
AlpHaRitEr's Avatar
Default E-brake light stays on
Hey guys, i got this problem.
It seems, like this only happens when my motor is cold.??
but I get in my car start it, and take off the e-brake and go... E-brake all the way down.. obviously. But light stays on... this has been like this for a few weeks now. I do believe the e-brake is entirely disengaged because the car doesnt feel like its got any brake applied to it.
I was thinking maybe it was some electrical wireing into my cluster? But i dont know what wire... or where.
Any help plz?
Old Jan 5, 2005 | 10:04 PM
pdiggitydogg's Avatar
how's your fluid level
Old Jan 5, 2005 | 10:27 PM
31flavorscivic's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">how's your fluid level</TD></TR></TABLE>
correct. Check brake fluid. Get back to us.
Old Jan 5, 2005 | 10:31 PM
_Cyclone_'s Avatar
Default Re: (31flavorscivic)
Yep... the reservoir has a sensor in it. If the fluid level gets too low, it sends a signal to the computer, which triggers the brake (idiot) light, no offense intended.
Old Jan 5, 2005 | 10:38 PM
BlueIntegraBoy's Avatar
Default Re: (CycloneBlue_1.6EL)
Do what they say, for Pete's sake, do what they say!
Old Jan 5, 2005 | 11:49 PM
JDMTYPER's Avatar
Default Re: (BlueIntegraBoy)
had the same thing happen to me and after checking everything I could think of it turned out to be the easiest thing, topping off the brake fluid.
Old Jan 6, 2005 | 11:11 AM
AlpHaRitEr's Avatar
Default Re: (JDMTYPER)
doh... thx gents... imma go check that out as soon as i get off work, and ill get back 2 u
Old Jan 6, 2005 | 11:52 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (AlpHaRitEr)
After topping off, check out your pads. If your fluid level is low, it is usually the first sign that your pads are getting worn down (then followed by the squeeler). If the pads are fine, I'de check around for any fluid leaks.
Old Jan 6, 2005 | 05:32 PM
AlpHaRitEr's Avatar
Default Re: (94eg!)
well... brake fluid filled to the rim, didnt have to add any.... any more ideas??
Old Jan 6, 2005 | 05:35 PM
94eg!'s Avatar
#1 Super Guy
Loved
Take apart your e-brake handle cover & make sure the switch is working.
Or, make sure the wires on the fluid cap are pluged in.
Also, you may need to take apart your fluid cap & make sure the floater is operating properly.
Old Jan 6, 2005 | 05:46 PM
AlpHaRitEr's Avatar
Default Re: (94eg!)
ok ill do that tomorrow and get back to u asap thx
Old Jun 2, 2015 | 06:48 PM
SohcZcCrx's Avatar
Default Re: E-brake light stays on
You never got back to him. What was it?
Old Jun 2, 2015 | 07:30 PM
Former User's Avatar
As stated in other thread, please create your own.
LunchboxZT
Sep 8, 2006 01:22 PM
.water
Jun 11, 2005 12:06 PM
Project91CRX
14
Apr 26, 2004 03:47 PM
vtec-izm
Aug 26, 2003 11:53 AM
pelotudo
Sep 25, 2002 07:11 PM
