B16 starting issue
Old Jan 5, 2005 | 08:21 PM
teler86's Avatar
Default B16 starting issue
My b16 will never start from the first try when it is cold what could be the problem
Old Jan 5, 2005 | 11:47 PM
PrettyLude's Avatar
more info please
Old Jan 6, 2005 | 05:50 AM
teler86's Avatar
Default Re: (PrettyLude)
Well it once it is warm it will start right up, but when the engine is cold i always have to give it exactly 2 trys to start up
Old Jan 6, 2005 | 06:17 AM
tgreaves's Avatar
Default Re: (teler86)
Could possibly be a main relay..
Old Jan 6, 2005 | 08:46 AM
PrettyLude's Avatar
Default Re: (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Could possibly be a main relay..</TD></TR></TABLE>
that's the same thing i was thinkin
Old Jan 7, 2005 | 09:47 AM
teler86's Avatar
where is the main relay located
Old Jan 7, 2005 | 02:30 PM
PrettyLude's Avatar
underneath the dash on the driver side, its held on by two 10mm bolts
Old Jan 10, 2005 | 02:33 PM
teler86's Avatar
how do i know if its busted
Old Jan 10, 2005 | 03:17 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 &raquo;</TD></TR><TR><TD CLASS="quote">Well it once it is warm it will start right up, but when the engine is cold i always have to give it exactly 2 trys to start up </TD></TR></TABLE>
I don't think it's the main relay. Try adjusting the throttle stop screw on your tb. I had this problem when mine vibrated out. After getting a replacement, I had to adjust it so that the throttle lever was slightly open. By adjusting that it added a tinge of fuel. It was enough to make the car start on the first try.
Old Jan 14, 2005 | 10:49 AM
teler86's Avatar
Default Re: (eda6)
i already adjusted the tb and its not it, how do i konw if my main relay is busted
Old Jan 14, 2005 | 10:57 AM
tgreaves's Avatar
Look at the main relay and find pins 1 and 7.. Put a jumper in there and try to start the car.. If it starts on the first try where it wouldnt before then your main relay is bad..
knightsef-eg
Oct 4, 2008 02:34 PM
ninjagaiden
13
Jul 6, 2007 03:44 PM
95excoupe
17
Jun 17, 2007 03:47 AM
TealCivic93
May 29, 2006 06:28 AM
DAMCOOLDAV
Aug 28, 2004 09:19 AM
