Suspension & Brakes Theory, alignment, spring rates....
99 ex rear sway bar
Old Jan 5, 2005 | 08:08 PM
eK9aT10pSi's Avatar
Default 99 ex rear sway bar
just a quick question, i got the whole setup from a 99 si. on the si, the bolts that go into the subframe has 2 nuts welded in from factory on both sides, on the ex, there are just 2 holes. the q is would i just need to get some 8x1.25x30mm bolts, nuts and lock washers? would that suffice? thanks
Old Jan 5, 2005 | 08:22 PM
gabebauman's Avatar
Default Re: 99 ex rear sway bar (eK9aT10pSi)
Yup...I've got the same exact set-up on my 98 ex
Old Jan 5, 2005 | 08:37 PM
eK9aT10pSi's Avatar
Default Re: 99 ex rear sway bar (gabebauman)
cool, just verifying that. any issues/problems that you encountered? should just bolt up with no issues? what bolt size did you use 8mm or 10mm ? thanks
Old Jan 5, 2005 | 08:41 PM
gabebauman's Avatar
Default YES 13mm = no tearout
Easy cheesy install...30min...tops. I'm not sure what size the bolts where, mine came with the sway bar (original owner had it installed on his ex also). Sorry
Old Jan 6, 2005 | 09:43 AM
eK9aT10pSi's Avatar
Default Re: YES 13mm = no tearout (gabebauman)
thats cool, ill get both and one will work
by the way, would you have any pix of ur install? thx
Old Jan 6, 2005 | 09:58 AM
gabebauman's Avatar
Default Re: YES 13mm = no tearout (eK9aT10pSi)
Not my car install...but same thing. http://www.hazone.com/hsirearsway.htm
Old Feb 1, 2005 | 07:35 AM
eK9aT10pSi's Avatar
finnally got it installed this weekend. it was a breeze. took like 15 min. the difference was very noticible, great improvement for the ek's w/o the rear sway bar
Old Feb 1, 2005 | 08:33 AM
gabebauman's Avatar
Awesome...glad I could be of some help.
Old Mar 10, 2005 | 10:56 AM
yoej8's Avatar
dont mean to jack thread, but i have a 98 ex and was lookin to get a gsr swaybar with lca's on ebay, the site didn't say anything about fitment on the ek. just wondering if it would still fit?
Old Mar 10, 2005 | 07:29 PM
eK9aT10pSi's Avatar
Default Re: (civek)
you can use the itr one but its not as safe as the si one. the gsr/itr ive read will rip the subframe. you have to modify the mount and get the endlinks. the itr lcas are too thin for the ek bracket.
Old Apr 25, 2005 | 01:40 PM
yoej8's Avatar
hi just wondering if anyone had any issues with the endlink hitting the exhaust. the parts that hit together are the exhaust and the bolt of the endlink connected to the swaybar.
ive searched n searched but only a few came up that was related and the rest was aftermarket swaybars. THanks
Old Apr 25, 2005 | 07:39 PM
eK9aT10pSi's Avatar
Default Re: (civek)
i made my own exhuast w/o any clearance issues. sure you got to correct endlinks for the right side becuase the part numbers are different. i realized that when i ordered them from honda. take a pic of your problem.
Old Apr 26, 2005 | 12:02 PM
yoej8's Avatar
im planning to cut the unused portion of the bolt of the endlink and just cut a groove in it so i can just use a flat head screwdriver in replacement of the allen wrench insert. if its a bad idea, just let me know.
Old Apr 26, 2005 | 07:37 PM
eK9aT10pSi's Avatar
Default Re: (civek)
i would 1st cut the exhuast instead of the bolt so it doesnt ruin the intergrity of the bolt. at times there is a lot of stress on one side or the other.
nghtshd88
Mar 4, 2012 02:32 PM
kasperxtcy
Suspension & Brakes
May 1, 2009 10:13 AM
pos_cd5
Dec 31, 2007 06:13 PM
Razor
Jul 25, 2002 12:03 AM
