Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
trailing arm s.bearing with fixed shaft
Old Jan 5, 2005 | 07:56 PM
eg6vtec1's Avatar
Default trailing arm s.bearing with fixed shaft
The PCI trailing arm bearing with the fixed shaft is in stock now at jhpusa.com some people were asking about that style, just saw it so I thought I'd let you guys know. I cant post any pics though maybe someone could.
Old Jan 5, 2005 | 09:41 PM
slammed_93_hatch's Avatar
Default Re: trailing arm s.bearing with fixed shaft (eg6vtec1)
i have the floating shaft one's sitting right here waiting to be installed
edit link to the new ones for the lazies http://www.jhpusa.com/catalog/...3e95a
Old Jan 6, 2005 | 10:26 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: trailing arm s.bearing with fixed shaft (slammed_93_hatch)
I still don't see why these guys don't add dust boots. It seems comon sense to me...
Old Jan 6, 2005 | 10:59 AM
MattD@Stoptech's Avatar
Default Re: trailing arm s.bearing with fixed shaft (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">I still don't see why these guys don't add dust boots. It seems comon sense to me... </TD></TR></TABLE>
j00 don't want dust b00ts on race cars...j00're supposed to inspect j00r suspension regularly.
Old Jan 6, 2005 | 11:13 AM
Tyson's Avatar
you cant anodize dust boots red. good idea tho.
Old Jan 6, 2005 | 12:06 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: trailing arm s.bearing with fixed shaft (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
j00 don't want dust b00ts on race cars...j00're supposed to inspect j00r suspension regularly.</TD></TR></TABLE>
That sounds a little silly to me. They could be held in place by a snap ring or something. It would only take a second to remove & pull back the boots. Then throw some more grease in & go. Plus, if you insist on not using them, you could just NOT USE THEM. I'de bet they would sell like crazy too...
The boots could be made in any color too...
Old Jan 6, 2005 | 11:15 PM
eg6vtec1's Avatar
there is a dust boot available, but you don't really need it, unless you plan on rallying, I just put a high pressure grease on the shaft and it holds up good to the rain and dirt, this type of grease wont wash out, and protects the shaft from any type of corrosion build up. recommended if the cars ran in the rain. dirt damages ball bearings easily not spherical bearings asks the off road guys.
Old Jan 7, 2005 | 06:19 AM
got a name for that grease?
Old Jan 7, 2005 | 06:51 AM
JeffS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i have the floating shaft one's sitting right here waiting to be installed
edit link to the new ones for the lazies http://www.jhpusa.com/catalog/...3e95a</TD></TR></TABLE>
This link says nothing about being fixed. In fact, since the previous product is no longer on their site, I would tend to think that it's the same floating shaft unit with the addition of slotted ends for whatever reason.
To the original poster... what a lazy post... no pictures, no details, no link... why even bother?
Old Jan 7, 2005 | 07:36 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: trailing arm s.bearing with fixed shaft (JeffS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">
To the original poster... what a lazy post... no pictures, no details, no link... why even bother?</TD></TR></TABLE>
I thought the same thing, but if you look again you'll see that the bolt holes on the shaft (were the two mounting bolts go) are slotted now. I'm assuming this is how you will be adjusting toe, and the compensator arms will be removed completely.
I have another question:
Would it be better for handeling to have fixed shaft bearings w/o compensator arms, OR sliding shaft bearings with compensator arms? So far, both parts have stated that their race only, so that original "street version" idea doesn't seem to apply.
Old Jan 7, 2005 | 01:38 PM
eg6vtec1's Avatar
Im running the fixed shaft. The car rotates a lot better with the fixed shaft. Id say about 10% more or so. you can get away with running less spring in the rear, you can still change the setup of the suspension to get the car to push a lot if you like a lot of push. The sliding shaft is still avalible. And the slots are to adjust the toe.
the grease I'm using is Zep super impact grease, it is a extreme pressure grease rated at 50,000 psi its green in color, mcmaster-carr sells it for like 5 dollers they will next day ship anywhere, www.mcmaster.com
Modified by eg6vtec1 at 10:59 PM 1/7/2005
c-techracing
Jul 7, 2007 10:56 AM
ImportPower13
11
Nov 22, 2004 08:55 PM
CTL
Mar 8, 2004 07:11 AM
Jaskula1
17
Jan 4, 2004 07:33 PM
c jackson
Dec 20, 2003 08:46 PM
