won't stop chirpping 4 times
Old Jan 5, 2005 | 07:49 PM
91ls-v's Avatar
Default won't stop chirpping 4 times
well when i unarm the alarm after it has been trigered it will never stop chirpping 4 times until i unplug the alarm or pull the fuse to reset it so...how can i fix this problem..
Old Jan 5, 2005 | 10:40 PM
fcm's Avatar
fcm
Old Fart
Default Re: won't stop chirpping 4 times (91ls-v)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ls-v &raquo;</TD></TR><TR><TD CLASS="quote">well when i unarm the alarm after it has been trigered it will never stop chirpping 4 times until i unplug the alarm or pull the fuse to reset it so...how can i fix this problem..
</TD></TR></TABLE> does it evan happen after you turn on the ign. if so check and make sure that the alarms ign. wire is hooked up properly 94
Old Jan 5, 2005 | 11:07 PM
91ls-v's Avatar
Default Re: won't stop chirpping 4 times (fcm)
still happens after i turn on the ignition...how do i know if the ignition wire is hooked up properly??
Old Jan 5, 2005 | 11:34 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ls-v &raquo;</TD></TR><TR><TD CLASS="quote">still happens after i turn on the ignition...how do i know if the ignition wire is hooked up properly??</TD></TR></TABLE> It need to see power when you turn on the ign. to the run position and on start but not on acc. or off. 94
Old Jan 6, 2005 | 08:03 PM
91ls-v's Avatar
i'm not quite sure which wire to hook it up to...can you give me some info on which wire please
Old Jan 7, 2005 | 07:55 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ls-v &raquo;</TD></TR><TR><TD CLASS="quote">i'm not quite sure which wire to hook it up to...can you give me some info on which wire please
</TD></TR></TABLE> The "true" ign. wire on a 91LS is Black/yellow at ign. harness. 94
Dask08
Audio / Security / Video
Sep 1, 2008 06:16 AM
HONDRETTI
May 6, 2008 08:04 AM
jay-d-em
12
Feb 19, 2007 04:50 AM
Quad-Damage
13
Dec 23, 2005 08:10 AM
PlikityPLAH
Feb 4, 2005 02:29 PM
