spark plug wires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F23Coupe »</TD></TR><TR><TD CLASS="quote">Get Crane Cams spark plug wires for dirt cheap at optauto.com. Look in the clearance section there. If shopping elsewhere or want different brands, get MSD 8.5 mm wires.</TD></TR></TABLE>
Hell yeah, thats what I'm sportin... They're really nice and thick as hell (11.5mm) and discontinued, so if that site still has some, get them!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts »</TD></TR><TR><TD CLASS="quote">What kind of NGK wires for $35....The HE* blue 7mm stock fit type ? Where ? </TD></TR></TABLE>
nopi.com sells them pretty cheap. $35 ones are for LX/DX accords, EX wires cost ~$55-60.
another thing what kind of cap and rotor should i get?? some guy that works on Honda's said that i should replace that because mine had some corrosion and stuff on it and wasn't firing completely right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jj84756 »</TD></TR><TR><TD CLASS="quote">another thing what kind of cap and rotor should i get?? some guy that works on Honda's said that i should replace that because mine had some corrosion and stuff on it and wasn't firing completely right.</TD></TR></TABLE>
oem - cap and rotor - fairly inexpensive ~$30 i think, dont remember
oem - sumitomo wires - about $60
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jj84756 »</TD></TR><TR><TD CLASS="quote">why should i stick with stock wires??? the ones on that one site would be cheaper than stock ones. (the ones on the site were 24.99, but they were 11mm)</TD></TR></TABLE>
because you will never get the quality of a oem or a ngk wire from a aftermarket company .... people have dynoed their cars with aftermarket wires and with oem wires and saw no gains when using the aftermarket wires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jj84756 »</TD></TR><TR><TD CLASS="quote">so since i have an EX model it will cost more for wires. about what size should i go with??</TD></TR></TABLE>
the size of the wire is just the protective heat resistant coating, not the actual wire itself. NGKs are 8mm which is a tad thicker than stock and is all you need. i like NGK over the OEM ones cause they blue looks nice. there are alot of cheap generic junk wires out there and alot of overpriced gimmicks.
well if the wires are cheaper than oem should i go with them because its not like i am going for better performence just better than the crappy ones that are on there cause they are old.
Honestly I would stick with oem (which is ngk
)because you're not only going to not really notice any performance increase going from a 7mm oem wire to a 8.5mm wire unless you're running serious power and or a upgraded ignition.
Check out http://www.importrp.com they have GREAT prices and awesome service:
https://honda-tech.com/zerothread?id=831208
)because you're not only going to not really notice any performance increase going from a 7mm oem wire to a 8.5mm wire unless you're running serious power and or a upgraded ignition.Check out http://www.importrp.com they have GREAT prices and awesome service:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jj84756 »</TD></TR><TR><TD CLASS="quote">ok i can get the cap, rotor, and sparkplug wires all oen, for $55. is that a good deal????</TD></TR></TABLE>
That's a real good deal if it comes with installation.
