Snapped end off of rear brake hard line..what to do now?
Went to install my earls stainless brake lines and i ended up braking the fitting off of the hard line. I have no idea how i should go about fixing this
not the best pics but you can kind of figure out what im talking about..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnydc2 »</TD></TR><TR><TD CLASS="quote">That sucks. Prolly going to have to replace that whole hardline.
was thinking the exact same, just hoping for a cheaper alternative..
</TD></TR></TABLE>was thinking the exact same, just hoping for a cheaper alternative..
This has happened to me and yes this is a HUGE PITA. The cheapest way to fix is to reflare the tube with a new fitting, but then your SS line will be slightly short. I would strongly recommend getting a new hard line. I wish I did, and if it ever happens again that is what I will do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 »</TD></TR><TR><TD CLASS="quote">You could probably cut the hardline back, re-flare it, and add another short hardline on (using an adapter, check with a brake supplier) to make up for the length lost.</TD></TR></TABLE>
sounds good ill give that a try once this bitch *** snow goes away..
Make sure you check with a shop that is certified to do state inspections, to make sure that repairing it like that is legal and will still pass inspection. I know that NY has some stupid inspection guidelines. Just don't want to see you do all the work for nothing.
pcguy760
10
May 5, 2007 10:02 AM
Jared
Nov 24, 2003 07:51 AM
