89 civic starting issues
Old Jan 5, 2005 | 05:44 PM
Riceburner247's Avatar
Default 89 civic starting issues
I'm working on a 88-89 civic DX 4dr (DPFI). Friend of a friends car, not mine.
It doesn't want to start, but will crank over just fine. There is a wierd pattern when I try. It will crank, try to fire, sputter, then go back to cranking, try to fire, sputter, etc.
I've already checked fuel. I pulled off the intake chamber and watched the injectors both squirt. I've already checked spark. I checked all plugs and even pulled off the dizzy cap to make sure all points were intact.
At this point, I'm hoping to christ that the timing is all fucked up. If it's not, I don't have a clue what the hell is wrong. I was thinking maybe a faulty resistor box, but both injectors fire fine, so fine that a backfire has singed my eybrows and goatee.
I'm headed to Schucks right now to buy a timing gun. Anybody else ever encountered this before or have a clue what's wrong?
Old Jan 5, 2005 | 05:49 PM
fourthgenhatchB17's Avatar
Default Re: 89 civic starting issues (riceburner247)
I dont think a timing gun is gonna do u any good considering it wont start. Since u said u pulled of the cap, im assuming u have done a visual inspection of the inside of the cap, the rotor, and ignitor connections? The only thing i think is next would be to check cam timing.
Old Jan 5, 2005 | 05:56 PM
Default Re: 89 civic starting issues (fourthgenhatchB17)
I've used a gun before, but the engine was running. I figured it would work in this situation.
:searches for "cam timing":
EDIT: Ok, I searched and didn't find too much on how to udjust cam timing. Anybody know how?
Modified by riceburner247 at 7:24 PM 1/5/2005
playa24vtec
19
Nov 5, 2013 09:19 AM
RufusHonda
Oct 6, 2012 12:21 AM
mygfs92lx
Jul 19, 2006 06:33 PM
distortion
17
Feb 3, 2006 12:55 AM
93Twinstick
Jan 30, 2006 07:19 PM
