98 lude dies when I step on the gas
Old Jan 5, 2005 | 03:47 PM
anomale's Avatar
Default 98 lude dies when I step on the gas
whats up My car just died getting on the freeway its not a t-belt problem because it starts and idles fine but when I give it some gas it dies anybody ever had this problem its a 98 lude stick non sh
thanks
Old Jan 5, 2005 | 04:22 PM
WeekH22's Avatar
Its a prelude thats the problem
Old Jan 5, 2005 | 04:25 PM
preludeez's Avatar
Default Re: (WeekH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WeekH22 &raquo;</TD></TR><TR><TD CLASS="quote">Its a prelude thats the problem
worthless post, and your first one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anomale &raquo;</TD></TR><TR><TD CLASS="quote">whats up My car just died getting on the freeway its not a t-belt problem because it starts and idles fine but when I give it some gas it dies anybody ever had this problem its a 98 lude stick non sh
thanks</TD></TR></TABLE>
any mods, is it completely stock?
Old Jan 5, 2005 | 04:26 PM
Hawkze_2.3's Avatar
Default Re: 98 lude dies when I step on the gas (anomale)
Check for any codes it may be throwing...
Old Jan 5, 2005 | 04:29 PM
hOndafienD 04's Avatar
might be a fuel problem....hows the pressure? check the tps also.
Old Jan 5, 2005 | 05:01 PM
fishdude's Avatar
make sure there is no water in the ditrbutor or the plug wires
Old Jan 6, 2005 | 12:50 PM
anomale's Avatar
Default Re: (preludeez)
its modded I just bought it a couple weeks ago here is what I know that it has
AEM Intake, Full DC exhaust, AEM adjustable CAM gears. Not sure if it has aftermarket cams (is there any way to tell by looking at them) also not sure if it is chipped. How can I check the fuel pressure and tps? does the ECU have a LED that blinks out the codes? Dist and plugs are dry. This is my first Lude I switched over from a civic so youe help is appreciated
Old Jan 6, 2005 | 01:08 PM
Hawkze_2.3's Avatar
Default Re: (anomale)
Check the codes by sticking a bent paperclip in the little blue plug behind the radio. Do a search if you need more info on this and the TPS adjustment, there's tons of info already there.
As far as I know you have to have a fuel pressure gauge to check fuel pressure...
Old Jan 14, 2005 | 11:30 AM
WeekH22's Avatar
heres another its a prelude # 2
Old Jan 14, 2005 | 11:54 AM
Akhany's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WeekH22 &raquo;</TD></TR><TR><TD CLASS="quote">heres another its a prelude # 2
WeekH22 =
I was also going to suggest checking the inside of your dizzy. And like everyone else also stated, check to see if you're throwing any code(s).
LaCuRa
Oct 13, 2008 07:22 PM
wjl120579
Apr 10, 2006 09:07 AM
nobwayner
Sep 23, 2004 10:05 AM
zzzhondazzz
Dec 6, 2003 08:19 PM
