i need help!! asap
Old Jan 5, 2005 | 01:04 PM
AZNBIGPIMPN505's Avatar
Default i need help!! asap
i have a 99 civic hx an i just had a cam gear put in an they adjusted the 6 degrees forward but im loosing alot of gas... can anyone help me step by step showing me how to pull it back to normal or 3 degrees.... i lost more than half my gas mileage i really need help thanks
Old Jan 5, 2005 | 03:13 PM
civic-4-ges's Avatar
Default Re: i need help!! asap (AZNBIGPIMPN505)
Who put it to 6 degrees??? That is a huge amount..1-3 degrees max, but 6!!
All you do is loosen the bolts, then you reference the same 6 degree mark you are working from, and put it back to a decent number.
Are you running a pre 1995 SOHC cam gear on your D16y5?
csoares
Transmission & Drivetrain
Oct 21, 2012 09:38 AM
Jdm4drEk16
Jan 20, 2008 09:54 AM
turbochic
May 31, 2003 01:03 AM
