Throttle body problem??
Old Jan 5, 2005 | 10:36 AM
SkySolGra's Avatar
Default Throttle body problem??
In addition to the jerkiness of the car.. the gas pedal was jerking along with it.. moving on its own revving the car and causing it to jerk down the road.. so could it be the throttle body and not the clutch? <<<https://honda-tech.com/zerothread?id=1104350
Old Jan 5, 2005 | 10:53 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Throttle body problem?? (SkySolGra)
Vacuum leaks, a bad TB gasket and a bad idle control valve on the bottom of the TB could all cause such symptoms.
spermdoggy
Jun 4, 2012 06:58 AM
d-it-big99
Oct 13, 2010 01:56 PM
kornkid21792
May 12, 2010 10:06 PM
Bakersfieldgsr
Nov 12, 2007 03:34 PM
Des9255
Oct 24, 2005 09:58 PM
