idle problems..sparatic idle..ATTENTION TECHS
Old Jan 5, 2005 | 10:16 AM
conceptEG's Avatar
Default idle problems..sparatic idle..ATTENTION TECHS
i have a 92 prelude si.. when i took the car home and started it again.. i noticed a drop in idle then it corrected..then drop..from around 1500 to 44oo.. i was thinking it was a vac leak somewhere but i checked.. no go.. replaced the throttlebody gasket and cleaned the t/b itself.. still same thing.. i removed the aic from the front of the manifold..seemed fine.. PLEASE HELP!!!!!!!!
THANKS GUYS..
Old Jan 5, 2005 | 10:29 AM
PrecisionH23a's Avatar
Default Re: idle problems..sparatic idle..ATTENTION TECHS (hatr-aid)
Clean out the IACV or replace it with a known working one. It's located on the intake manifold with 2 coolant hoses going to it. It also has a harness going to it that also ties into the harness for the 4 injector clips.
apbtwhiskey
Apr 5, 2013 01:51 PM
HIallday
Sep 13, 2011 10:34 PM
89CivicHb1
Jan 4, 2009 11:00 AM
allmotorsi04
May 11, 2004 04:49 PM
dustinsterk
Dec 31, 2003 04:10 AM
