Need help, Car wont start.
Old Jan 5, 2005 | 09:50 AM
DSGB.'s Avatar
Dirty Bird
Default Need help, Car wont start.
95 Accord EX-L F22 Vtec, Drove it home from wrk yesterday, Didnthave a bit of problem out of it, Got up to goto work and it didnt start. Got lights,headlights,stereo,ect.. so the batt is fine, I tride jumping it and hav a batt charger on it just to be sure, It wont turn over, Start does not click or anything, Just does nothing. Plase help me out.
Old Jan 5, 2005 | 09:59 AM
Filthy Focker!'s Avatar
Default Re: Need help, Car wont start. (Birdman.)
If the starter won't click or spin, but you do have some voltage to the lights and such, i first suspect the battery is dead. DO you have a friend that could swap the battery out of his car and try it?
fs
Old Jan 5, 2005 | 10:06 AM
tspencer227's Avatar
Sounds like a bad solenoid if you've got auxiliaries but the engine's not turning over. Check that, then check your starter motor too.
Old Jan 5, 2005 | 10:40 AM
DSGB.'s Avatar
Dirty Bird
Took the batt out of my accord and put it in there and it did the same thing, I just changed the starter in my accord last week, Wehn it went bad it would just click, This one dont make any noise or anything.
Old Jan 5, 2005 | 10:45 AM
Default Re: (Birdman.)
You sure you got power going to the starter? Got a test light or a multimeter?
fs
Old Jan 5, 2005 | 10:49 AM
.bagged's Avatar
Default Re: (filthy_shovel)
Main relay
Old Jan 5, 2005 | 11:34 AM
DSGB.'s Avatar
Dirty Bird
where is the main relay located?
Old Jan 5, 2005 | 12:12 PM
Superorb's Avatar
im having the same problem. every once in a while the car wont start. thought it was the battery but it's new. used a multimeter, have 12.5v on the battery when its sitting and also same when i goto turn it over. nothing happens, it's like the clutch isnt being pressed, but it is. sometime last week, it took liked 2 seconds of the key to start b4 it would crank. not sure the problem.
Old Jan 6, 2005 | 04:55 PM
honda accord's Avatar
main relay..under driver side dash.....
Old Jan 6, 2005 | 06:33 PM
PrettyLude's Avatar
it sounds llike the ignition switch is going bad
Matt Montgomery
Dec 11, 2017 09:18 PM
needhondahelp90
Nov 25, 2014 11:46 AM
racquetgirl222
Sep 19, 2010 04:12 PM
crunk_accord
Mar 10, 2009 03:04 PM
Just_me_chris
Jan 8, 2009 03:32 PM
