Squeeky shifting!?!
When I shift it sometimes is really really squeeky and chunkish feeling as well. It sometimes even makes that "fast and the furious" CHING! noise too not quite but it sounds similar...anyone help me out??
mine makes the squeeking noise and it gets worse when it rains so i think that if i use some white lithiume grease on the buchings it will stop if that is the problem. sorry not realy any help but check your bushings and o-rings on the shiter.
um....sounds like ur not pushing the clutch when u shift...
although im sure u r,..i think its ur tranny's outta line or ur shift fork..
i kinda tried 'mastering' shifting w/o the clutch
, if u get it at the right rpm its perfect, but every now and then if u **** up, u get the cRiNGgG sound/feel from the gears grinding a bit
... could be the tranny all together..
how many miles r on it?
?how many miles r on it?
it has 115000 on the 95 ex coupe and 50k on the gsr. what you said make since becasue the rear mount bracket is not correct and the motor is twisted a little but not for much long i got the right part
I do put the clutch in when I shift. I am not an idiot. It doesnt grind when I shift its just a noise from the shifter itself. And when you grind when you shift it is not the gear plates that grind its the dog place that does. I am guessing that its what PABLOHONDA said I will just have to check the bushings possibly replace and grease em up! Thanks guys, and sorry bauleycivic didnt mean it to be offensive!
JustEFit
Jun 23, 2013 06:22 PM
em1gangsta
Jul 29, 2008 01:11 AM
