Suspension & Brakes Theory, alignment, spring rates....
rear suspention makes a big thump when compressing around a corner
Old Jan 5, 2005 | 06:36 AM
drewbie's Avatar
Default rear suspention makes a big thump when compressing around a corner
ssometimes when I am making a turn that changes in elevation (like a foot at the most), my right rear suspention will make a big thump. Kind like if you hit the bottom of the car with a big hammer.
It hasnt caused any problems, but its like holy crap is something broken? did something brake?
I think it might be the spring but im not shure. I have tokicos with hyperco springs on coilovers.
94 hatch
Old Jan 5, 2005 | 07:04 AM
Mike_C's Avatar
is the car slammed? you could be hitting a bumpstop.
how many miles are on the shocks? they could be blown, but i'd think you'd hear the noise more often than you are.
have you checked all the bolts? one could be loose, but again i think you'd hear this more often than you are.
is the spring loose? you might not have preloaded it enough.
have you checked your bushings? one might be gone.
Old Jan 5, 2005 | 09:54 AM
AlxSiR7's Avatar
Default Re: rear suspention makes a big thump when compressing around a corner (mr. teal Type R)
i'm having a similar problem.. check out my thread https://honda-tech.com/zerothread?id=1104404
Old Jan 5, 2005 | 11:09 AM
modthispny's Avatar
Default Re: rear suspention makes a big thump when compressing around a corner (AlxSiR7)
Doesn't that mean the shocks are blown? When the car bottoms out. My brothers old 2001 Cobra did that.
Old Jan 5, 2005 | 05:13 PM
ice11honda's Avatar
I would say it is your spring, as one tire hangs lower than the rest the spring decompress and shoots up into the tower making the noise you're hearing. Pre-loadiing may possibly fix this.
Old Jan 5, 2005 | 05:37 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
maybe it's binding somewhere?
Old Jan 6, 2005 | 06:08 AM
drewbie's Avatar
Default Re: (MugenDude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude &raquo;</TD></TR><TR><TD CLASS="quote">maybe it's binding somewhere?</TD></TR></TABLE>
that thats what it sounds like....it hasnt done it in a while...but i think its the spring.
could jsut be the rear alignment too
Old Jan 6, 2005 | 06:58 AM
turboman's Avatar
Is your car really slammed?
Inside will become unloaded then pop back into place.
kellogg97rs
Suspension & Brakes
14
Mar 30, 2007 10:31 AM
ckyguy
Suspension & Brakes
Aug 19, 2005 09:24 AM
Slow
Dec 17, 2003 11:40 PM
makaveli284
Feb 27, 2003 11:22 PM
Roadrnnr
Sep 5, 2001 09:53 AM
