turbo questions
Old Jan 5, 2005 | 12:02 AM
hlub29's Avatar
Default turbo questions
I am trying to buy a turbo and piece things together. any help will do. My goal is 450-500 whp. turbo of choice is GT30R with full race exhaust manifold and 3"dp. The question is on the turbo turbine, it has .63, .82 and 1.06 A/R what does all these mean. For the wastegate, it is 38mm, 40mm and 44mm which one is the best for my application. The last one is I plan on driving it 15psi daily and the track 20-25 psi. which spring rate would I need to get for my wastegate. My engine management of choice are autronic or hondata. any info or feedback would be appreciated. Hlub29
Old Jan 5, 2005 | 12:07 AM
NJAman's Avatar
Default Re: turbo questions (hlub29)
read like the basic info on turbos and you will understand everything a lot more. I wouldnt get that setup until i knew wtf everything was at the very least.
Old Jan 5, 2005 | 06:03 AM
DaX's Avatar
DaX
Loved
Community Favorite
If going with FR components, I recommend giving them a call and discussing your goals with them. The guys up there are very knowledgable.
Old Jan 5, 2005 | 11:56 PM
PrettyLude's Avatar
Default Re: (DaX)
full race
Old Jan 6, 2005 | 04:01 PM
eg6T's Avatar
Default Re: (PrettyLude)
if you want daily driven at 15psi and race at 20-25psi...you will have to get a 1 bar(14.5 right) spring and a boost controller. whatever the psi is for that spring you choose will be the lowest you can adjust to on the boost controller.or u can just change out your springs in the wastegate all the time
whoneedzvtec
Aug 3, 2006 06:40 PM
stickshiftt
Apr 7, 2004 10:39 AM
B20-T
Jul 28, 2002 12:39 AM
