Clutch line issue in h22a SWAP...help me out guys
Old Jan 4, 2005 | 11:02 PM
crx4life2002's Avatar
Default Clutch line issue in h22a SWAP...help me out guys
Now that the car is wired up, shift linkage is installed, extended the fuel line ive come to another snag. Were does the clutch line go? The metal line running off the slave cylinder on the del sol has a fitting with a flared end. The fitting is to large to use on anything on the del sol tranny? Any ideas
Old Jan 5, 2005 | 01:44 AM
duofilm's Avatar
Default Re: Clutch line issue in h22a SWAP...help me out guys (crx4life2002)
Well the simplest way is to get a couple AN fitting's and slap a steel-braided line with the proper length. Otherwise you're gonna have to remove the bigger nut but cutting it and replacing with the smaller one, which you'll have to reflare to the correct size.
Pics courtesy of "integrasi"
Modified by duofilm at 2:55 AM 1/5/2005
eddie422
May 10, 2011 05:32 PM
metal41mulisha
Jun 5, 2009 08:07 PM
B18c5__Owns
Mar 25, 2009 12:48 PM
prelude72569858
Sep 14, 2008 08:00 PM
crx4life2002
Jan 16, 2005 10:36 AM
