Just got a B16a1 swap done
Old Jan 4, 2005 | 10:22 PM
B18Mario's Avatar
Default Just got a B16a1 swap done
Few months ago i got a B16a1 from osaka motors and this engine REd lines at 7500 anyone got ideas why and yes im using the PR3 computer...
Old Jan 4, 2005 | 10:29 PM
bloopie's Avatar
Default Re: Just got a B16a1 swap done (B18Mario)
And why would you need to go much higher than that?
Old Jan 4, 2005 | 11:32 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Mario &raquo;</TD></TR><TR><TD CLASS="quote">Few months ago i got a B16a1 from osaka motors and this engine REd lines at 7500 anyone got ideas why and yes im using the PR3 computer...</TD></TR></TABLE>
My guess is you are using an automatic ECU.
Hybrid96EK's Avatar
Default Re: Just got a B16a1 swap done (tuner.fish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuner.fish &raquo;</TD></TR><TR><TD CLASS="quote">And why would you need to go much higher than that?</TD></TR></TABLE>
Because they are supposed to wind higher and make peak power at 7,600rpms.
Old Jan 4, 2005 | 11:58 PM
bloopie's Avatar
Default Re: Just got a B16a1 swap done (Hybrid93Eg)
I knew that...
Ever think that his tach is a bit off and he really is hitting 7600?
Old Jan 5, 2005 | 02:03 AM
L.'s Avatar
L.
From: On an island,, In the middle of an ocean, USA
The ecu is most likely an automatic ecu, best option would be to purchase a chip from e-bay and have it installed at a local shop. If you do purchase the chip it would be a good idea to also buy some type of rev limiter because most chips if not all eliminate the rev limiter. MSD has a couple of options, normally hondas will use one of the MSD6-series products.
Old Jan 5, 2005 | 03:17 AM
2lua's Avatar
that ecu is jdm b16 dohc (rsi/xsi).http://www.pgmfi.org/twiki/bin/view/Library/EcuFamilies
Old Jan 5, 2005 | 08:31 AM
boostedbseries2000's Avatar
the motor stops making power at 7900 anyway
Old Jan 5, 2005 | 09:50 AM
Hybrid96EK's Avatar
Default Re: (boostedbseries2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedbseries2000 &raquo;</TD></TR><TR><TD CLASS="quote">the motor stops making power at 7900 anyway</TD></TR></TABLE>
No, if its a stock engine it quits making power at 7,600rpms. This was already covered in a post above.
Old Jan 5, 2005 | 10:03 AM
menkio's Avatar
Default Re: (Hybrid93Eg)
osaka
redskull1944
Engine Management and Tuning
Oct 4, 2008 09:17 PM
EGwhat!!!
11
Mar 16, 2006 07:15 AM
B18cHatch06
109
Jan 6, 2006 03:57 PM
Hfacegstare
Nov 2, 2005 03:26 PM
westspeed
Sep 4, 2004 11:35 AM
