HELP!!!!!my integra doesnt start!!!
make sure your starter wire is connected good. (the one that goes from the terminal strait to the starter. make sure the power wire to the fuse box is in the right slot and not in the negative slot
If you've installed anything electrical recently go back and see if something came loose. You might have knocked a wire loose hittin a bump hard or left a wire loose. I don't know too much about this, but that would be the first thing I would do.
Good Luck
- Nick
Good Luck
- Nick
asocallocal
Jun 22, 2010 01:06 PM
