Suspension & Brakes Theory, alignment, spring rates....
wierd scrapping noise
Old Jan 4, 2005 | 08:41 PM
HmgLauj69's Avatar
Default wierd scrapping noise
my front driver side (spindle/hub/whatever you call it) scrapes everytime i make a right....first came to mind was the dust shield, i bent the hell out of it but the scrapping is still there...my right is starting to do too but on a regular basis....i just replace my lower ball joints, could that be the problem
Old Jan 5, 2005 | 12:35 AM
Tyson's Avatar
Default Re: wierd scrapping noise (HmgLauj69)
when you replaced your lower balljoint, did you have the metal ring that plugs into the hub and encircles the axle joint ever fall out?
its easy for these to pop off, especially when you push out the balljoint because theyre a bit in the way, but theyre a pain to get back in straight. mine was loose and would make a scraping and metal tinny ringing sound. i had to use a grease can to match the circumference of the ring to evenly push the ring back in position.
Old Jan 5, 2005 | 11:49 AM
HmgLauj69's Avatar
Default Re: wierd scrapping noise (Tyson)
not sure what your talking about, i'll post pic up later so you can tell me what to look for
Old Jan 6, 2005 | 12:53 PM
HmgLauj69's Avatar
pic doesn't work
Old Jan 6, 2005 | 12:56 PM
Tyson's Avatar
heres another pic. #2 .
Old Jan 6, 2005 | 01:09 PM
HmgLauj69's Avatar
when you look at it can you clearly tell if it's lose of not?
Old Jan 6, 2005 | 01:22 PM
Tyson's Avatar
nope, i had to take my axle out first to check. once i did, it just fell off since it wasnt being held in.
Old Jan 6, 2005 | 01:37 PM
HmgLauj69's Avatar
thanks i'll take a look this weekend, you guys have any other sugguestions to what might it be?
jdmdelsol96
Nov 8, 2008 05:26 PM
thatwhiteguy
May 30, 2007 04:07 PM
2nd_Gen
Aug 23, 2005 01:08 AM
Doubledeala
Jan 29, 2005 12:14 AM
tuan...
Aug 2, 2004 06:31 AM
