FRUSTRATION!!!
oh my God! i jsut parked my car, and tried to take the key out of the starter! the dam key wouldnt come out! i was able to start the car, but sometimes it would turn over and teh car would not start... any way after much trial and error, i was able to get my key out of the dam starter... what the hell is the problem? do i need a new key and starter? is this even possible to do and how much would it cost/!?!! AHH!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SalmanzCivic »</TD></TR><TR><TD CLASS="quote">oh my God! i jsut parked my car, and tried to take the key out of the starter! the dam key wouldnt come out! i was able to start the car, but sometimes it would turn over and teh car would not start... any way after much trial and error, i was able to get my key out of the dam starter... what the hell is the problem? do i need a new key and starter? is this even possible to do and how much would it cost/!?!! AHH!!</TD></TR></TABLE>
First of all you didn't pull your key out of your starter.. Your starter is in the engine bay.
Your key goes in the ignition.
I have no idea what the problem could be.. Never heard of anything like this.. You could maybe try putting some lube on the key and then sticking it in.. or the teeth may be messed up in the ignition.
goodluck
goodluck
when u say key cylinder. u mean to just spray wd-40 into whole in which the key should go in . correct? i just want to make sure thats wat ur sayin, if not then do u mean some where behind the panel? sorry .. im a newbie.
Don't use WD-40 in the ignition (the place where you put your key in to start the car). Use "graphite", you could get it in the automotive section of any grocery/drug store.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SalmanzCivic »</TD></TR><TR><TD CLASS="quote">when u say key cylinder. u mean to just spray wd-40 into whole in which the key should go in . correct? </TD></TR></TABLE>
Yes, after you spray WB-40 in, cycle the key in and out then cycle it forward and backwards. You should feel the key start to turn easier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9civic5 »</TD></TR><TR><TD CLASS="quote">Don't use WD-40 in the ignition (the place where you put your key in to start the car). Use "graphite", you could get it in the automotive section of any grocery/drug store.
Graphite will do nothing for a stuck pin. The only reason you would use gradhite over WB-40 is that WB-40 retains water.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
Graphite will do nothing for a stuck pin. The only reason you would use gradhite over WB-40 is that WB-40 retains water. </TD></TR></TABLE>
yea, graphit works great if you actually maintain it before it goes bad. A stuck pin you kinda need a solvent/lube that won't gunk up, so wd-40 works great.
funny, because wd-40 was first invented to displace water..... not even ment to be a lube.
